Cylinder heads
Carl1234
- What model do you have?: 1971 1300 beetle
Cylinder heads
Howzit going everyone. Unfortunately both my 1300 twin port heads have cracked between the valves and spark thread. I have found a guy selling new heads but they look as though they are for a 1600 TP will these work?. Alternatively is there anyone on here with 1300 TP heads that they’d be willing to sell. Thanks
- No More Landy
- Has thanked: 23 times
- Been thanked: 6 times
Re: Cylinder heads
I also noticed that slight sign of a crack in the same place but I just left it. What symptoms did your engine have?
Sent from my SM-A107F using Tapatalk
1971 Beetle
2021 Polo tsi
2006 Defender Kalahari
2021 Polo tsi
Carl1234
Re: Cylinder heads
No symptoms was doing a rebuild and noticed that they are quite badly cracked and would like my engine to run like new
Re: Cylinder heads
I've got 20 pairs of heads on their way to SA soon. Theyll be here late January.
Re: Cylinder heads
Tony Z wrote: Sat Dec 18, 2021 6:20 pm I've got 20 pairs of heads on their way to SA soon. They'll be here late January.
Are they STD.
Do you have a set of "tickled" heads in stock
When is the CT workshop open again.
Re: Cylinder heads
They will be standard but anything can be made to work better
Nothing in stock right now. Its taken me nearly a year to get these 20 pairs.
I'll be back in operation from Feb again
- Riaan.N
- Oil Seal
- Has thanked: 3 times
- Been thanked: 38 times
Re: Cylinder heads
Hi Tony, put me down for a pair pleaseTony Z wrote:They will be standard but anything can be made to work better
Re: Cylinder heads
message me the end of Jan pleaseRiaan.N wrote: Tue Dec 21, 2021 4:43 pmHi Tony, put me down for a pair pleaseTony Z wrote:They will be standard but anything can be made to work better
I'll be back in operation from Feb again![]()
Carl1234
Re: Cylinder heads
So as it turns out my 1300 twin port has actually been turned into a 1600 twin port. This is nice as heads are readily available but sad at the same time as I understand that 1300 TPs are rarer
- Has thanked: 141 times
- Been thanked: 100 times
Re: Cylinder heads
I understand how you feel. My ‘71 has its original 1300 TP engine, of which I recently had the heads rebuilt. I would hate to change to 1600 TP.Carl1234 wrote: Thu Dec 23, 2021 1:03 am ….sad at the same time as I understand that 1300 TPs are rarer
- No More Landy
Re: Cylinder heads
My engine is also 1,3 converted to 1.6.
Engine out busy with push rod tubes.
Difficult without an engine stand or workbench
1971 Beetle
2021 Polo tsi
2021 Polo tsi
- Pushrod
- Been thanked: 107 times
Re: Cylinder heads
Boet,....if you are the "custodian" of aircooleds,....you invest in an engine stand !,.....your swearing jar will take longer to fill up!!. Believe you me !!
Got a basic one at Adendorff's
- No More Landy
Re: Cylinder heads
Due to time constraints I ended up with a beer crate and another empty crate with the engine standing upright on one cylinder head at a time to change pushrod tubes. Worked pretty well with additional ratchet strap from the roof trusses
1971 Beetle
2021 Polo tsi
2021 Polo tsi
Re: Cylinder heads
Hey all
For those interested, I have received stock of new Autolinea heads.
R3000 each or R5750 for a pair.
Whatsapp me or call if interested, 0833418937
