Hi Guys
I am struggeling to get my new push rod tubes amd seals to remain aligned and not push to one side even though I stertched them all a little and make sure they are dead straight when I start to pull the head down evenly.
Two of them are pushing over to one side and squeezing the new seals unevenly.
fighting to get push rods in
- No More Landy
- Has thanked: 23 times
- Been thanked: 6 times
- Been thanked: 98 times
Re: fighting to get push rods in
I use a socket extension of a similar dia to the tube ID and as I tighten the heads i keep the tubes lined up using the socket extension to pull the tubes true.
- No More Landy
Shot thanks. Will give it a bash once I clean off all the loctite sealant
Sent from my SM-A107F using Tapatalk
1971 Beetle
2021 Polo tsi
2006 Defender Kalahari
2021 Polo tsi
- No More Landy
That worked 100%
1971 Beetle
2021 Polo tsi
2021 Polo tsi
