1968 VW T2 Harness
andrewgdbn@gmail.com
What model do you have?: 1968
1968 VW T2 Harness
Post by andrewgdbn@gmail.com »
I am looking for some guidance on replacing or repairing a wiring harness on a 1968 VW T2 - it seems the previous owner did some damage when the indicator stalk stopped working and he fitted a toggle switch on the dash. Now the wipers are not working nor the toggle for the indicators. Not sure if the harness can be replaced or repaired? Many thanks.
Re: 1968 VW T2 Harness
Best and easiest would be to fix the old Harness.
Getting a new Harness and fitting it is not that easy in the bus.
Go on to Google and get a wiring drawing for your model and sort out one wire at a time.
The indicator Stalk can be got from Volk Spares or Autostyle.
Good luck
Thanks Herman.
Been thanked: 107 times
Post by Haans »
Andrewg,...i know very little bout electrics,..but can gather upvery little common sense I might add,.....and a test lamp AND then you progress to a Multimeter '๐Ÿ•ถ ๐Ÿ‘€๐Ÿ‘€๐Ÿ˜๐Ÿ˜๐Ÿ˜™๐Ÿ˜‡ let me tell you ,..you'll even surprise yourselves !!
Forums such as this and others can be very helpful too.
Try it.
Regards Haans
