1976 T2 Baywindow Door Cards.
Get your parts here
Ianscott0464
What model do you have?: Kombi
Post by Ianscott0464 »
Good evening all,
Any information as to a supplier of T2 Baywindow door cards (bare) would be gratefully received.
Been thanked: 100 times
Re: 1976 T2 Baywindow Door Cards.
You’d probably have to import if local guys like Autostyle don’t have. What works for me on all my cars is to stick some trace paper/plastic on your door and trace out the outline and clip holes. I then transfer the pattern to 2mm ABS plastic, which I get from Maizey’s. The ABS’ thickness is closest to the original and is resistant to moisture. The board that is commonly used is 3mm, which is too thick.
Ianscott0464
Many thanks for your suggestions I am actually abroad and can source the cards but they will be too big for my suitcase so I was hoping to find them in SA.
