Hi there.
I have recently had a new carb installed. (Both old carbs would not idle, flat spots etc) this new one idles great, runs smooth no flat spots etc.
One problem I am having is on cold start it starts perfectly. After a short drive to the shops, when starting again it struggles then once started it splutters and smells like petrol for a bit, after a minute or 2 runs smoothe again.
Is this the carb over fueling on shut off?
Is it bad for the engine or just an inconvenience?
How to fix it?
Or what else can it be
Many thanks in advance
Sent from my SM-G985F using Tapatalk
Carburetor
- What model do you have?: regi
Re: Carburetor
Take it for a drive, and when you get home, take the air filter off and look down the carb throat. As the carb warms up (no more cold air flowing thru it to keep it cool), you might see fuel dripping onto the butterfly. If you do, this is your problem and it is killing your engine by diluting your oil with petrol.
Hopefully your supplier can help you fix the problem
- evan.fraser.274
- What model do you have?: T3 FB, T2 Bay, 63 T1
- Has thanked: 23 times
- Been thanked: 9 times
Re: Carburetor
You don't specify the type of car but I assume a Beetle given your mention of a "carb" and not "carbs". Is it an OEM design carb (i.e. either an original Solex or a Solex copy), and but does it have the cut-off solenoid? I know that a faulty solenoid can affect the cut-off of fuel overflow when the carb is hot and the car is off (although issues with this will mean the vehicle will not idle if the faulty solenoid is closed). If you have a spare solenoid, perhaps swap it out. It could be jammed open...shaggy10111 wrote: Mon Feb 27, 2023 7:47 pm Hi there.
How to fix it?
Given enough time and money, anything is possible...
