's up?
1. I need a roofrack repaired PROPERLY. It needs very fine welding and needs to be smoothed afterwards...I don't want the welds seen.
2. I need someone to bend a small bar and rework it so that it can have a top screwed onto it, etc. to repair my wheelchair with.
Any suggestions?
Thanks, N.
Welding and custom metalwork...
- Merlin
- Has thanked: 20 times
- Been thanked: 39 times
- Merlin
:s
Next time I'm out at the bee-baa, I'll take a pic of the wheelchair lock for you, and see how it gets removed...perhaps I can send it your way...it's not a very complex bit.
Probably about 15cm in length, with a 30' or so degree bend in it.
The top has a screw-on plastic cap, but I've forgotten what the bottom looks like...
It's one of the locks that holds the wheelchair to the floor rails.
Cheers, Nic.
Cheers, Nic.
- Merlin
Shot Chris.
I think I've filled all my time slots after work and on weekends and my weekends until the end of the decade.
Crikey, I need a clone - or three.
Thanks for the offer. I'll definately take you up on it as soon as I get a chance.
Cheers, N.
Cheers, N.
