Hey Dubbers,
Would anybody know how to make original Porche cookie cutters fit on a 65 bus?
The wheels are15" 7J. ET offset is unknown, but they do touch the insides of the wheel arch on the test ftting. PCD is 5x130 i think?
Adapters seem to be the answer but i'm sure its not that simple
Advice would be appreciated or point me in the right direction.
Thx
Porche Cookie Cutters on Early bus
- Single Port
- Has thanked: 13 times
ive got the 15x7 dials on my bus. no problems. ET is 42, and my adapter is about 30mm thick. its tight on the rear lip, but does not rub. 195 tyres
Do it! now!
Do it! now!
- Single Port
chances are if they touch the spring plate w/out the adapter during a trial fit, they will be fine.
- 2BugMe
- What model do you have?: 1974 Type1
- Been thanked: 2 times
Oh, and by the way could you please forward me some picture of said conversion to adriaan.d@vodamail.co.za
Thanks brianJ
Thanks brianJ
- Single Port
we are saying essentially the same thing. spring plate is at the back of the wheel, fender lip at the front.
have mailed you
have mailed you
