SCAT Urethane tranny mounts
Greetings all
I would like to use the SCAT mounts, but need the following questions answered:
1. The rear tranny mount; Would the Beetle one work in the Type III? The Volkspares dude reckons that the Type III mount is different from the Beetle one, but the Urethane ones could be modified to fit...
2. What is the quality of the SCAT parts like?
3. Are there any local stockists?I have a plan to import them for around R300-00, failing which, I have the option to buy INSOFORM ones from a fellow forum member :wink:
This is for a Fastback that is going to have a mild Type 4 engine. Are there any other worthwhile modifications that I could do?
If I'm not mistaken: If its a swingaxle T3 then it it will be the same as beetle...
Just be aware that the urethane mounts transmit a lot of engine noise to the car interior.
fig wrote:Just be aware that the urethane mounts transmit a lot of engine noise to the car interior.
Modern soundproofing takes care of that, from what I have been told...
eben wrote:If I'm not mistaken: If its a swingaxle T3 then it it will be the same as beetle...
Thanks Eben :D
Has thanked: 36 times
Been thanked: 50 times
Post by flatfourfan »
a LOT of vibration as well..........it makes the whole rear set-up a lot more solid.
forcecooled
Post by forcecooled »
Nick was selling PU bits
Thats the beauty of having hard suspension... I never noticed a difference after install the urathane mounts on my car... just turn the music up if it annoys you
Riftvalleyvw
What model do you have?: Love Bug
Location: Nazereth, Ethiopia But Stuck in Los Angeles at the moment....
Post by Riftvalleyvw »
The Urethane mounts are strong and hard and will last you a long time compared to the stock mounts. But they DO transfer a lot of Vibration to the car. No way to soundproof that. I used to put them in my Bugs untill they invented the removable face plates for the car stereos. When you use the Urethane mounts with a proformance motor the face plates pop off all the time from the vibration.... Now I just use the rubber ones for on road applications.
Are you going to be a hard launcher :?: Robot racer :?:
Bugger wrote:Are you going to be a hard launcher :?: Robot racer :?:
It's going to be a cruiser, no hard launches for me :wink:
yea sure, thats what you say now, until the BMW w#nker sits next to you.... :lol:
Tony Z wrote:yea sure, thats what you say now, until the BMW w#nker sits next to you.... :lol:
I can't wait to give the BMW wankers a go :twisted:
At a later date, after the Fastback is properly sorted and running, I would like to add some boost, that's when I will add the Kafer Cup Bar and solid tranny mounts :? :shock:
dont bother with the solid mounts... get urathane, a Kafer cup bar and the mid-mount tranny mount
Tony Z wrote:dont bother with the solid mounts... get urathane, a Kafer cup bar and the mid-mount tranny mount
Like I said, that will be in the distant future, after the car is sorted 100%
For now, I am getting SCAT or INSOFORM mounts, this should be sufficient :D
