The wiper motor problem is concerning a Super Beetle 1303 (European) model that has got the intermittent relay included in the circuit. I have manually drawn two circuit diagrams on paper, cutting out everything that has got nothing to do with the wiper blades. Please refer to the image at the bottom of this post. (if the links go dead at any point, let me know by PM so I can fix it).
So here is the problem. Since the first time I used the wipers, with the intermittent movement, the blades would not always 'park' in the 'zero' position. Sometimes it parked higher up the wind screen after each cycle. And that is NOT normal behavior. It seemed that the circuit(or whatever) had to warm up at first, and after a few cycles, it would park properly. This I thought suspect from day one...
So one day on the way back from work(nice and sunny day, funny enough!!) the wipers just switched on by itself
The first time I pulled over, I pulled EVERY fuse, but the wipers would not stop
Now, to make a short post long, here is my question to you auto-electricians out there.... I want to remove this relay from my circuit, and get the wipers to work again. I dont really need the intermittent function. That is why I have included both diagrams on one page, to reference the two and 'cut out' what needs to be cut. Auto electrics is not really my thing, but when push comes to shove, I CAN do it. It just takes me longer to figure things out. For those of you that this is a piece of cake, can you please advise me how I should tackle this problem.
Thanks in advance
(if my drawings are not clear enough, let me know and I can go into detail)
Now for the pic:
