Bearing sizes
ZeroAxe
Drive Train
Bearing sizes
Post by ZeroAxe »
Hey fellas,
SO this Golf I front brake disc conversion that you guys do. Can I ask of you guys for the dimensions of the 'off size' bearing? I believe you said that it is the outside bearing, right? So I know that the ID of the bearing is the Beetle spindle, and the OD is the Golf's rotor.... but I need sizes (of the bearings that is, puh-lease!!!!!). I am going ot have a sot at this conversion myself, just need ot source those bearings.
Thanks!
VW Enthusiast
Zeroaxe. Don't quote me on this but I'm sure the diametres are 22 mm and 40 mm. But here is the bearing number you are looking for: HR32004XJ 6-10. The thing to note is, are you using the same hub conversion that we are using here in SA?
Outer bearing as on Type3, inner bearing Type1, for disk kit made in SA
