Page 1 of 2
The alternator stand...
Posted: Wed Nov 14, 2007 11:53 am
by Merlin
I seem to remember asking someone about this a while ago?
I belive the alternator stand is, like the block, Magnesium...so will paint not stick to it?
I want to paint it black, polish it, and clearcoat it...possible?
Thanks, N.
Posted: Wed Nov 14, 2007 12:09 pm
I painted mine with CS4 primer.
Posted: Wed Nov 14, 2007 12:13 pm
by Merlin
2K no good?
Otherwise I'll send it off to Bugger...he's using some wierd stuff to paint my gearbox with...also a paint-sticking problem part apparently.
N.
Posted: Wed Nov 14, 2007 12:44 pm
I know very little about paint. I do know that the CS4 primer did stick and it comes in black, white or red.
Posted: Wed Nov 14, 2007 12:54 pm
by Merlin
Thanks.
I'll speak to Bugger, as it needs to be somewhat more glossy than that, and I suspect that I'm going to have the same issues painting my alternator shroud plate, and the gearbox sideplates - Alu.
N.
Posted: Wed Nov 14, 2007 1:00 pm
my alternator and plate was also done with that paint. Once the primer is on, you can always paint it in another colour.....
Posted: Wed Nov 14, 2007 1:02 pm
by Blitzkrieg
That black alternator stand looks cool :cool:
Posted: Wed Nov 14, 2007 1:03 pm
by Merlin
Mmmmkay...thanks.
Will have to brush it on, with my ideas, and then finish it off with a Shiteload of masking...detailing a few places on the car. ;)
Posted: Wed Nov 14, 2007 1:06 pm
Blitzkrieg_Beetle wrote:That black alternator stand looks cool :cool:
Thanks and now its also got a bling chromed filler and filler cap :wink: :lol: :wink:
Posted: Wed Nov 14, 2007 1:10 pm
by Blitzkrieg
I'm going to paint my engine tin matt black, with a matt silver engine fan shroud and gearbox.Silver and black detailing :D
Posted: Wed Nov 14, 2007 1:22 pm
silver on the gearbox.... hmmm thats smells like an overheated box...remember silver reflects heat back to where it came from, thats why its used as heat shield paint......
use it, dont use it
mush or not mush
drive or walk
Posted: Wed Nov 14, 2007 1:23 pm
by Blitzkrieg
Tony Z wrote:silver on the gearbox.... hmmm thats smells like an overheated box...remember silver reflects heat back to where it came from, thats why its used as heat shield paint......
use it, dont use it
mush or not mush
drive or walk
:o
Never knew that!!
When the time for detailing comes, we shall see :)
Posted: Wed Nov 14, 2007 1:26 pm
detail in black with silver striping. Black works well to eject heat
Posted: Wed Nov 14, 2007 1:28 pm
by Blitzkrieg
So I can't make my Type 4 shroud silver then ?
Posted: Wed Nov 14, 2007 1:32 pm
yes you can, the cooling air runs through it....The air does the cooling, not the shroud.
The gearbox is only cooled by the casing radiating the heat to the surroundings, if you return that heat to where it came from, it wont cool.
