Is this or is this not a correct bug steering column and mount, and more importantly, is it correct for a Euro '67?
Thanks, N.
Hi,
Mine is nothing at all like that [US-spec] in your photo.
I've just gotten off of the phone with another mate, who is
a little confused.
He too has a '67 and reckons although similiar, my column
is slightly different to his - original.
Here are a few photos of the setup.
Without doubt no holes have been closed in the dash. The
metal is perfectly clean under the bonnet/hood. What's there is what was there in '67, and what's on the column - OG or not - was there in '67.
The two buttons on the dash are lights and hazards.
Indicators/flashers and wipers work by way of the column.
I haven't had a chance to dig through my heap of parts to
find a Euro '68 column I got earlier this year - plus it's
the middle of the night here, but I do know from memory
that the ignition lock atleast is different, and the two
can't interchange from what I gather. The '68 has a small
lock mechanism.
TheSamba lists my bug as a FEB '67. It is a German sunroof,
if that helps.
Surely a FEB is not close enough to the '68 year to start using '687 parts?
A friend suggested the fuse box looked like it had been enlarged, but there's no sign of metal mods there either.
Here is the quote from my friend...
It appears that the fuse box cut-out has been enlarged, and the box/module that houses plug in relays , etc has been fitted in the place of the standard unit.
That weld on the steering column tube is as good as the factory could turn out. - It may be that the top part of the tube is thicker walled than the bottom part to allow for extra strength for the locking mechanism.
The crumple coupling on the lower end of the steering shaft is a great improvement. - Keep it
The steering column itself along with the levers is very similar to the much later bugs, but as there are no obvious hacking and patchings on the dash metalwork other than at the fusebox surround, one can assume that the car had a similar setup as standard.
The ledgends on the levers belong to a later time than ' 67.
The steering wheel boss is definitely not genuine VW, unless its an accessory.
The ignition switch certainly looks like its quite late, and the wire connectors are definitively not run-off-the mill 65.
Any clues?
Thanks, N.
