Lowering the front suspension on the beetle.
- What model do you have?: Jeep Replica
Morning fellas.
Our beetle sits high in the front. Looks odd. Is there anyway I can drop it a bit myself? The back is sitting nicely its just the front.
- Merlin
- Has thanked: 20 times
- Been thanked: 39 times
Re: Lowering the front suspension on the beetle.
A stock bug does sit slightly higher in the front.
If you read up on the bug design, they were designed that way, but I can't give you a technical explanation. Helped with the handling.
N.
N.
the easiest way to drop it is to put in a 50kg bag of whatever....
Otherwise contact Calooker or Bugger, I am sure either of them could help you out.
ahh ok.. Thanks Merlin.. Is there anyway to drop it a bit though that you are aware of?
thanks Tonyz. I thought about that but that will result in the car not pulling as normal and we cant have that
its a case of stripping the suspension out, then taking it apart. Welding in some adjusters and putting it all back together. More labour than anything else. Then you can adjust it to stand any way you want...
damn.. I thought there was an easy way of doing it.. lol
- Merlin
There are a myriad of ways, the two most common being welded in adjusters - get the right ones for your beam (l/k pin, or b/j - of which there are 2), or drop spindles - which push the wheels out further - in some cases, making it an issue.
Those are the two most common, and by far the least complex.
Welding in adjusters need to be done by someone with expertise in the field...angles, location, welding, etc.
N.
N.
At least us Type 3 guys don't have to weld in adjusters and all that witchcraft
We just have to adjust the front torsion bars 2 splines without cutting and the car sits at a beautiful stance
Yes,yes,try to justify driving those carsBlitzkrieg_Beetle wrote:![]()
At least us Type 3 guys don't have to weld in adjusters and all that witchcraft![]()
- Merlin
Chris wrote:Yes,yes,try to justify driving those carsBlitzkrieg_Beetle wrote:![]()
What do you guys have against the Type 3 anyway?
It's more aerodynamic and gives a better drive than a Bus or a Bug
- Merlin
This is indicative of the car, and the type of people who drive them...Blitzkrieg_Beetle wrote:What do you guys have against the Type 3 anyway?
lol, ja nee.
thanks guys. I've got a spare front suspension so i'll play with that one and then see what happens
check these 2 pages to get the idea.....
http://www.csp-shop.de/cgi-bin/shop2/sh ... 8231225881
http://www.cbperformance.com/catalog.asp?ProductID=428
