My 1915cc type 1 build
4agedub
Been thanked: 13 times
Post by 4agedub »
After a lot of thought I decided to build my 1915cc engine again as a spare for the cabrio.
The engine will feature:
Standard 69mm crank with welded counterweights
Standard connecting rods, equal weight
Mahle 94mm pistons and sleeves (Short shirt)
Scat c65 camshaft
Full flow type 1 engine casing
Cromoly pushrods
Modified type 1 cylinder heads with 42mm and 38mm stainless steel valves and double valve springs.
Twin weber 44idf carburetors
Now my idea here is to build a high revving toy. This engine should be capable of going up to 8000rpm with no problem. The short skirt sleeves help keep piston mass down and shorten the whole engine.
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
4agedub
Re: My 1915cc type 1 build
Post by 4agedub »
4agedub
Post by 4agedub »
sounds like fun.
What are the specs on the cam? CR?
Ever considered using lighter components, like tit retainers? :lol:
4agedub
Post by 4agedub »
4agedub
Post by 4agedub »
4agedub
Post by 4agedub »
4agedub
Post by 4agedub »
4agedub
Post by 4agedub »
4agedub
Post by 4agedub »
4agedub
Post by 4agedub »
4agedub
Post by 4agedub »
4agedub
Post by 4agedub »
The valve springs has already got titanium retainers. I want to retain the dual springs for high rpm use.
The camshaft is a Scat c65
C65 .440" lift 318 degrees PRO TRACK: Mini Indy/Super Vee grind. Excellent for variable RPM applications
The static compression ratio will be in the region of 12:1. I'm not sure if we will run dry sump or simply the deep sump setup.
stock rods and stroker pistons.... are you machining down the barrel??? Pics.
When is this engine going to be running by?
4agedub
Post by 4agedub »
Yes, I'm machining down the barrels. I'll post some pics as soon as I get the barrels back from engineering.
This engine should be running by end of next month. :)
