Mellow's V-Rod
- vader
- Has thanked: 9 times
Re: Mellow's V-Rod
This section....
Is this normal????
Is this normal????
MELLO YELLOW
- What model do you have?: 71 Bug, 69 Westfalia
Re: Mellow's V-Rod
Ahh OK
That is just something that I saw in either ultra Vw or V world mag
I just think that it looked
with that piece like that, But I need to make a brace for it so that it does not bend upwards.
If I do get tired of it I can always cut it off.
- vader
Re: Mellow's V-Rod
So will it help you to pick up more seatcovers? Or let them show you their hooters? Or is it just for shits and giggles?
I suppose I'll just have to wait till it's Finnish to see what the end result is......
MELLO YELLOW
- 4agedub
- Has thanked: 4 times
- Been thanked: 13 times
Re: Mellow's V-Rod
Nice colour. Looks really good.
Are you going to run a extended front end? Or just turn the front suspension around to increase the wheelbase.
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
MELLO YELLOW
Re: Mellow's V-Rod
No I am keeping it standard
otherwise I have to extend the steering column and that is too much work
I want to get it finished
- Barry
- Single Port
- Been thanked: 12 times
Re: Mellow's V-Rod
Oh sh!t - not much chance of me getting mine done then............MELLO YELLOW wrote:......... otherwise I have to extend the steering column and that is too much work
Keep those pics coming Mello!!
Barry
MELLO YELLOW
Re: Mellow's V-Rod
So sorry Barry
Its too late for you now, your car is looking so good now you cant start cutting corners now
As I said before this is a quick project to get rid of some surplus parts that I have laying around, and if someone wants to buy it oneday then that is also OK
Re: Mellow's V-Rod
Don't we just love pictures
What paint did you use for the inside, Mellow? Is it normal Matt Black or Chassis Black? And what brand?
In any case, the pan is looking beautiful. Now get that body on there
MELLO YELLOW
Re: Mellow's V-Rod
Thanks for posting the pics blitz
I used a chemical resistant paint, Carboline 938 (red) and Carboline 188 HB (black)
The inside of the pan is done with a "special" technique
which gives it that matt look and rough texture
The body has already been mated with the pan but as of yet I do not have any pics
But as usual you will be the first to see them (sorry make that second
- vader
Re: Mellow's V-Rod
4agedub wrote:Nice colour. Looks really good.
I dont understand this one... Please explain....
MELLO YELLOW
Re: Mellow's V-Rod
Vader ,which one do you not understand, if it is the latter one i too do not understand
- Barry
- Single Port
Re: Mellow's V-Rod
I am guessing the idea would be to make it into a leading arm, rather than trailing arm design
While I am sure it would still go down the road, I'm not sure I'd want to be in the vicinty.......
Barry
