I've got that - from cbperformance. Problem is at low pressure the pump overwhelms the regulator and it can't seem to get the pressure down low enough. It's already on it's lowest setting. I'm now thinking of putting the pump on a variable speed control - change the voltage to control the pump (even as I write that it seems not a good idea) Maybe I must just hunt around until I find a pump that will work. Max pressure 1.5 bar and enough flow.Tony Z wrote:you get pressure regulators that have a turbo manifold pressure connection. They will then keep you fuel at 4psi above whatever pressure they see in the manifold
FI - I'm starting to look at that option, only problem for me is that will change the whole look of the motor - all flat and modern.
