- dubster
- Been thanked: 3 times
Re: My ex type 1 turbo project (Changing to Historic Racer)
So we seeing you at zwartkops the 9th of may??
1974 1300tp type 1
kart kraft 1717cc buggy
- 4agedub
- Has thanked: 4 times
- Been thanked: 13 times
I think we'll be there.
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
- 4agedub
I drove her to work today, took the longest way possible
She did not miss a beat.
Just setup the timing today. ( I have not got a timing light at home)
I'll put some milage on her this weekend then we'll se what she can do.
- Has thanked: 19 times
- Been thanked: 58 times
Good to hear she is running good luck
I need to pick up the Toys I bought from you still will you have them at home or work
LEMME know
LEMME know
- 4agedub
What toys...? Some guy came around and collected them. He drove a combi... and he had a BAD side step.
Just joking with you, they're at my house. Let me know when you want to come around.
Side step
That was more than a Side step
But what the hell it was good
Ok will gill give you a call next week after work than will collect them
What time do you get home +-
- beetlefanatic
- Has thanked: 8 times
- Been thanked: 12 times
Nice Louis! Hope all goes well. I would love to check you and your bug in action on the track.
Dubster, you say Zwartkops is on the 9th of May? I need to make a plan to attend.
- dubster
Yes bf its the inland cars and bikes,9th of may,probably starts at around ten,but check out zwartkops site as the time comes closer theylle have all the details...4age are people allowed to view the cars in the pits?id like to see yours and meet you?
1974 1300tp type 1
- 4agedub
You would be able to go into the pits. They're not too fussy about that.
- dubster
Cool ill definitly come take a look...when are we gonna see some pics with the new mags and stuff all race ready?
1974 1300tp type 1
- 4agedub
Pierre, ek is gewoondlik by die huis vanaf so 7pm. Laat maar weet waneer jy wil kom.
[dubster] I'll take some pics during the weekend and post it.
Took her for a drive last night again. The carbs def need more sync, she feels terrible at the bottom. Full throttle seems ok. According to the data logger she makes 81kw at the wheels at 6800rpm.
I've tested the data logger before and it was really acurate.
For the logger you enter the cDa, weight, tire size and gear ratios. The logger has a built in accel meter and gps.
- vader
- Has thanked: 9 times
There is a thread in Advice which will talk you through balancing the carbs out. It's quite easy to do give it a try...
- 4agedub
I'll have a look again tonight. It's just a timely story.
Bought myself one of those EMPI PRO sync tools for the job. It's worth every penny!
Forgot to mention, on the data logger I've got the engine bay temp hooked up as well. The sensor is located just above the nr3-4 carb. Standing still in the garage, the bay temp went up to 35'c. Driving around the block twice it went down to 18'c. So lifting the bootlid up on top does make a hige difference it cooling. Ambient temp was +- 14'c.
Good idea
Good info
Good info
- vader
Chrome dome must be on lunch hence the short post....
