1965 DC project
- Muderick
- Has thanked: 42 times
- Been thanked: 69 times
Re: 1965 DC project
HI guys, some more pics of work that was completed in the last few days... The front and rear suspensions were cleaned, overhauled and painted. The gearbox was sorted and cleaned, the reduction boxes were completely stripped and new bearings and seals were added, before being reassembled and spray painted with black NS5.
The drums were all cleaned and NS5 spray painted, and were done over sometime in the past as they did not even need skimming...
I guess, the DC will be ready for rust removal and new panels soon... cant wait to get that started.
On the motivation side, we intend rebuilding a 1500 single port motor for it (as per OE spec) and for me this is always the best part of any build.
A few pics added, and chat soon!
On a more positive note, I will hazard a completion time of some time this year, so look out for it in George 2010!
Ps: we only work on Scruffles after work hours and on Saturdays.... so that is why it will take this long....
Muds
Muds
Old School or Bust!
- Muderick
Re: 1965 DC project
...also added some more pics of 12 April 2009... pick up day...
Old School or Bust!
- Muderick
Re: 1965 DC project
...more
Old School or Bust!
- Muderick
Re: 1965 DC project
...more
Old School or Bust!
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 322 times
Re: 1965 DC project
And right after George we'll be seeing you and the bus at the Kaapse Kombi Kult kamp-out!Muderick wrote:On a more positive note, I will hazard a completion time of some time this year, so look out for it in George 2010!
Re: 1965 DC project
Muds I wouldn't want to meet you in a dark alley at night
'll never diss a rat ride again, okay Muderick Boss!!
- Muderick
Re: 1965 DC project
Blitz: Ok my lightie... if I catchu i'll belt you! lol!
Believe me im a bleeder not a fighter
Fig: Goblin is already saying we must makes plans to come up....its gonna be a long drive!!!!!
Old School or Bust!
- Muderick
Re: 1965 DC project
Latest update on our 65 DC project.
In the past few days the following happened:
*Rear suspension, gearbox, and reduction boxes were cleaned, overhauled and painted. added some pics of before and after.
*Drums and backing plates were cleaned and painted
*Steering box (ZF nogal) was overhauled, seals replaced, the one that I replaced it with had an OD of 1mm over stock size, as apparently the OG sized one is no longer made. I sorted this by removing the outer layer of plastic on the bench grinder, and it fitted snugly a few minutes later.
We also started on the removal of the cab floor, passenger cab floor, and load bed bottom floor. There was a lot of damage but nothing we should not be able to handle. At least now we can see the offending areas. Henry has also sourced a few plans of the net and we have decided on the best one with which we are going to build a rotisserie for the bus. We decided on a caged type variation where the front and rear attaches to a 8 sided hoop. To move the bus body, we simply roll the entire body from angle to angle. Also, this type of rotissrie/cage takes up less space and provides the most access to the body. Will add pics once completed.
More later
Muds
More later
Muds
Old School or Bust!
- Muderick
Re: 1965 DC project
more...
Old School or Bust!
- Muderick
Re: 1965 DC project
more...
Old School or Bust!
- Muderick
Re: 1965 DC project
more...
Old School or Bust!
- 1972
Re: 1965 DC project
looking good
just a Q will that type gearbox fit onto a bug or will mods be needed?
