How do you drop a bug?
Has thanked: 19 times
Re: How do you drop a bug?
After I have Helped 1972 Aka Shane with his with welding the narrowed beam together I will see how much work is intailed to do this Then might do this for the guys and even if they just ask nicely :D
I remember there was somebody on the forum who has actually posted he has done one and can do it for fellow members
Do a search
bugspray
Floorpan
Has thanked: 24 times
Been thanked: 16 times
Post by bugspray »
That was Matt. Check under the my ride section.
buggyfan
Long Block
Has thanked: 95 times
Been thanked: 87 times
Post by buggyfan »
bugspray wrote:That was HOTTROD. Check under the my ride section.
:hangloose: :hangloose: FIXED
buggyfan
Long Block
Post by buggyfan »
bugspray
Floorpan
Post by bugspray »
You the man buggyfan.
You see no need to re invent the wheel ifis already invented :D
I am sure I will be able to do this in JHB for the one or 2 that might need it
Been thanked: 98 times
Portugal
Post by calooker »
If you a disk brake conv. the wheels tuck in nicely under the fender for the "narrowed beam" look. Only drawback is that the turning circle is reduced same will happen with a narrowed beam.
Post by 1972 »
Bugger wrote:After I have Helped 1972 Aka Shane with his with welding the narrowed beam together I will see how much work is intailed to do this Then might do this for the guys and even if they just ask nicely :D
Do a search
Pierre I picked up the metal I need for the gussets it should be cut soon and then it will be off to you...thanks again :hangloose:
Some of the things you will need to do if you narrow the beam is...
Narrow the tie rod assemblies either cut and weld in the middle or cut off what needs to be cut off on the end and retap in the correct direction.
Then the tortion leafs have to also be narrowed.
Then you must decide if you want to run shocks or not and that will determine what uerathane bushings to buy (long or short).
then its just the small things that have to be done...
Tristram
What model do you have?: 1974 luxbug
Post by Tristram »
Bugger what does it entail to install the adjusters at the front does it need any special equipment, or just a full bottle of mr daniels?
Tristram
1974 LuxBug 1600 AKA PIG
"Im a slave to my aircooled"
Tristram wrote:Bugger what does it entail to install the adjusters at the front does it need any special equipment, or just a full bottle of mr daniels?
:D Just a full tank of the stuff
No the only special equip neeed is the Mig welder,Hand pipe cutter and a Hack saw.
