Hopefully my parts payment went through today, in which case here is what i'm getting...
Engel 110
90.5 pots + pistons +rings
40X35 heads with SS valves and Single hi rev springs
Scat Crank 69mm (counter balanced)
Rear Main seal R50
High Ratio Rockers 1:25 lift
Cam lifters
Gasket set
36HP Shroud (Without dog house cooler, I’m running a new external oil cooler and it is working like a dream. Themoswitch kicks the fan in at 80 degrees( inlet Temp), I have pressure even after a 145km/h highway run)
Cylinder cool tin
Dual thrust bearings for cam
Will still need:
OG tinware for twin port.
Mains bearings
Possibly welded Race fan
Crank breather kit
New jets for my carbs
one new electric choke for solex 32/34 carb (left hand side)
Still need to do:
Machine case
Machine Heads to 8:1 CR
Weld case by No 3 cylinder
Lighten flywheel (maybe)
Plus other bits and pieces
PS, if you wondering about the name, This engine is going to be black, the case, the heads, the tin ware, the alternator, the works
And No, not gloss black, Flat or Satin...
I already have my box back from Bugger with a longer 4th, Front Disc conversion from Calooker and now waiting for parts.
After this, look out for my next build thread... it might entail metallic Charcoal gray paint and my SP...
pictures will follow as i get parts and make progress...
I'll put the gear box pic up soon...
If you don't like my parts choices then dont read this thread
But suggestions are Welcome
