Sleepy Time......
- Klaus
- Has thanked: 13 times
- Been thanked: 11 times
Sleepy Time......
Has anyone got a design for a pull out bed for a bay or better yet a R&R setup they want turn into christmas funds!
Taken out the middle row of seats for camping but just a little cramped so looking at making a better plan to ensure some back road camping trips this holiday season dont get ruined by grumpiness from lack of sleep !
- beetlefanatic
- Has thanked: 8 times
- Been thanked: 12 times
Re: Sleepy Time......
I have that same problem. I still had my middle in but turned facing backwards so my daughter could sleep on it, but it's a bit cramped. I'm also keen on another type of seat. I'm reading a book called "Coverting VW Van or Bus to Camper" (or something like that
). Anyway, there is a pic in that of a fold down rear bench. The pic is small and there are no measurements, but you get the idea of what they did. If you remind me in 2 weeks time, I'll scan it for you when I'm home.
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 322 times
I don't have plans or anything, but you're welcome to come and take drawings/measurements of the bed/seat in my 69 westy.
- Klaus
Thanks Fig - appreciate it - does the bed in your westy have a spring mechanism on it or does it just slide out. This I check and VD Brink to see if he has an old one in need of some TLC.
- Eugene
- Has thanked: 59 times
- Been thanked: 65 times
Now if you guys get hold of another forum member called Sean, he might just be able to help you. He made one for his Bay Panel and mine for the Split.
Try him on [img]seanwebb@telkomsa.net[/img]
- fig
- Bus Driver
No spring, just a system of levers. The mechanism kind of rocks forward and upward when you pull the bed open. Basically it does two things: firstly it pulls the seat base forwards and raises it, and secondly it lies the seat back down flat.Springer wrote:Thanks Fig - appreciate it - does the bed in your westy have a spring mechanism on it or does it just slide out. This I check and VD Brink to see if he has an old one in need of some TLC.
- Klaus
Samba - Do you perhaps know Sean on a personal level - sent him a mail but had no response.
Very eager - want to use the van this holiday !
- Has thanked: 18 times
- Been thanked: 58 times
SambaOwner wrote:Now if you guys get hold of another forum member called Sean, he might just be able to help you. He made one for his Bay Panel and mine for the Split.
Hy Boerra Uegenenenenene
Dont you wanna speak to Boera Sean and tell him there are 3 def clients and a possible 1 more who would like 2 for bay and mine and John Hoffe for split busses
ASSSSSSEblief
- Eugene
I should see him this afternoon. If not at least I'll get his number. Will let you all know by tomorrow
- Klaus
sweet!
- didi
- Has thanked: 9 times
- Been thanked: 37 times
My '72 rear bench/bed is out at the moment while i'm doing the restoration. If anyone wants to to take pictures or measurements while it's out of the bus your'e welcome.
_______
- Klaus
Didi
Are you located in JHB ?
- didi
I'm in Pretoria.
_______
