Numerous engine/mechanical bits available.
- dsan
- Twin Port
Just entered a garage of a guy who has 20 years of veedub parts available and is clearing it all out. I'll be heading down there again tomorrow with a camera and notepad, but thought if anyone needs anything mechanical, reply to this thread and I can always ask him.
To give you an idea, he has:
- more cranks than you can imagine
- engine blocks 1100 all the way up to the water cooled kombi range
- oil coolers
- tin
- dual carbs (webers, solex's) all complete with linkages
- original 1100 silencer, never used, perfect condition
- 1100 engine bits (just got rid of an entire 1100 engine for 200 bucks)
- suspension
- hundreds of cams, pistons the lot
5 garages and storage areas of bits.
So, if you are in dire need of something, let me know and ill ask him to have a look.
- oil coolers
- tin
- suspension
Daniel
catfish
- Oil Leak
- What model do you have?: 1957 beetle
Re: Numerous engine/mechanical bits available.
Hi there
Does he have anything for a 57 beetle in the line of wheel drums and all the bits that go with it?
- sarel.wagner
- Pushrod
- What model do you have?: T1 x 4, Split SCwide
- Facebook: http://www.facebook.com/sarel.wagner
- Been thanked: 2 times
Dual solex, anything for a '63, rubbers, spares, carb, heads etc. etc.
Regards
Regards
What other people think of you is none of your damn business
- dsan
- Twin Port
I have a set of rear drums for a 58/59, ones. brand new and all greased up.
will ask him for the rest tomorrow
Daniel
- dsan
- Twin Port
Sarel, he does have dual solex's, will get you a price. Head wise, he has more heads than you can imagine. any specifics?
Daniel
- sarel.wagner
- Pushrod
Are these things new? 1200 single port heads and covers, valvetrain, valves or complete set heads. Also 2.0L aircooled heads for a bus. 1700 Type 4 Fi case?
Regards
Regards
- Been thanked: 98 times
Interested in cylinder heads for 1600
1100 silencer
Weber carb kit
1100 & 1600 piston kits
Send me your Cell # I will give you a call.
1100 silencer
Weber carb kit
- dsan
- Twin Port
Most of the parts are used, i'll know more tomorrow when i spend some time there. Have put all your requests on a list to ask him
Daniel
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 322 times
Apart from the 30hp bus exhaust as discussed, I'd be interested in buying everything.
- Muderick
- Has thanked: 42 times
- Been thanked: 69 times
Dual Webers please Daniel, and 87 mm piston and barrels, or bigger PLEASE??
Old School or Bust!
fig wrote:Apart from the 30hp bus exhaust as discussed, I'd be interested in buying everything.
- Skymac
- What model do you have?: Bay window
I have more than 5 garages, if no one takes the whole lot
Once a fanatic, always a fanatic- Skymac
I am looking for 1300 and 1600 tp heads and tin, if there are good casings, I would also be interested.
If there are still dual carbs available, I would love a set or two
also manifolds etc
also manifolds etc
Once a fanatic, always a fanatic- beetlefanatic
- Has thanked: 8 times
- Been thanked: 12 times
Dsan, if he has any fuel injection stuff and type 3 engines/parts or type 3 glass, I'm interested.
