Steering Wheel Resto, My Dremel and I...UPDATES
zubz
Post by zubz »
Decided to repair and restore a spare wheel I have for the bug.
1. Routed out all old cracks using Dremel with carving/engraving bits.
2. Filled using Pratley Liquid Epoxy.
3. Left overnight to harden, no viagra's guys.
4. Filed some akward areas using hand files.
5. Sanded larger areas using Dremel with sanding circles.
6. Smoothed nicely and then primered using white primer, I reckon it will show the ivory/cream color better.
7. Now all I need is somebody to spray the wheel...
Some pics of the work, start to end.
YvaneS
What model do you have?: :)
Has thanked: 11 times
Re: Steering Wheel Resto, My Dremel and I...
Post by YvaneS »
Nice.. its looking good
zubz
Post by zubz »
YvaneS wrote:Nice.. its looking good
Tx.
Post by 1972 »
Wow it came out nice!
Barry
Post by Barry »
Wheel looks good!
Is that rattle can primer? No reason why you shouldn't spray it yourself.
Barry
Barry
Harry Jones
Post by Harry Jones »
Very very nice Peter .....!!! Looks Good ....A job well done
zubz
Post by zubz »
Barry wrote:Wheel looks good!
Barry
Thanks Barry, yeah it is rattle can. Cost like R38. I thought about it. You reckon I should just spray it myself? Maybe I should give it a try. I can always send away for spraying if I dont like it. Somebody quoted me like R300 to spray it.
zubz
Post by zubz »
Thanks guys...!!
69bug
Post by 69bug »
Like you said, spray it yourself and then decide if it looks good.
If you could repair it, you can spray it! :D
Hloni
Has thanked: 14 times
Post by Hloni »
Will paint stick on the 'plastic'?
Nice work though boet :hangloose: Would indeed be lekker to see the final product!
*bookmark*
3011
lowlight
Post by lowlight »
I used 2K and that worked.
Used piece of poly cop pipe upright in a vice with a long roof(10cm) screw about 5 - 10 cm from top.
Put steering wheel in so that it can turn freely and spray the wheel top and bottom.
zubz
Post by zubz »
Hloni wrote:Will paint stick on the 'plastic'?
*bookmark*
In order to get the paint to stick I had to sand and prepare the wheel nicely and remove the shiny layer. Once flatted nicely you can primer and if the primer sets nicely shouldnt be a problem for paint to stick.....
zubz
Post by zubz »
lowlight wrote:I used 2K and that worked.
LL, sure you have a compressor and spray gun? What color 2K did you use as I am trying to get this to the Ivory/Creme style color. Also do you have pics of the setup with the vice?? Sounds easy but always nice to see a pic...
lowlight
Post by lowlight »
Will take pics, mixed the paint.
zubz
Post by zubz »
lowlight wrote:Will take pics, mixed the paint.
Cool.
