long term project German look aka BENZIN
IMPI
What model do you have?: sp2
Been thanked: 78 times
Post by IMPI »
I have been dreaming of a German look bug for a very long time and even had a soft core one a while back still unsure whether selling it was a good idea.
I bought a 1302 heap from Pine a while back is a seriously complicated transaction and eventually decided it was too far gone to warrant rebuilding. The search was on for a better body Pine posted a sad looking 1303 on the forum and eventually it ended up at Volkspares sans chassis
Pierre brokered a deal (hy is nogal goed met deals...)and the shell ended up in my back yard.
I decided to start collecting parts and here is a few of what I have found so far.
My oldest was kind enough to drag everything from hiding
the 944 setup includes a rear anti roll bar and fits into the stock 1303 chassis
Plan for the seats is red vinyl with red harnesses
Found a NOS. apron from Ernst
Early passats and late 1303 beetles shared the same rack (LOL) I still need dimensions for the mounting brackets though
Naturally for a type four the badge should have a 4
another deal his Wife did not like the shifter
Dash will be modified 911 style and I like the understated looks of the SP wheel
944 (83 to 85) brakes bolt on to late 1303s
cooler will be in the front underneath the apron
My eldest stripped about a millimeter worth of paint off the car and we found some acident damage but not much rust
I still need quite a bit of kit and will be adding as I find
dubster
Re: long term project German look aka BENZIN
Post by dubster »
nice impi show us all how its done!is that a rollcage for the bug?thats my plans for the buggy one day..basicly a pipe car with a buggy body over it...looks awesome cant wait to see it unfold!
1974 1300tp type 1
kart kraft 1717cc buggy
Now this is what I've been waiting to see for a long time! Nice collection of goodies you have there Armand :deflag: German Look Beetles rock :hangloose:
69bug
Post by 69bug »
Armand, with your previous experience (silver german look, type 3, type 4 turbo) I know this project will be MEAN.
Cant wait for the updates. :twisted:
Now this is a project......I'm going to enjoy following this one! Good one IMPI!
*** Karmakoma fetches the proverbial popcorn ****
Now here is a project I am going to watch closely. Can't believe how many porsche parts are bolt-on.
Impi, isn't it cheaper to build two of the same while you are at it :-) ?
I'll start looking for that 1303 body so long :mrgreen:
Has thanked: 235 times
IMPI wrote:I bought a 1302 heap from Pine a while back
Uhm...more of a 'scratch my back, I'll scratch yours' deal I'd say - as there weren't any 'buying' involved? :roll:
But yes, looks were indeed deceiving and the 1302 was a HUGE disappointment. HW2, say hello to your IRS 'box & Porsche gauges and Sarel - I present to your Bug's sunroof...
Bestaluck with the build, IMPI! :hangloose:
Now that's a great base car to start with......like the sunroof!
Now bolt on some earlier venders and bumpers....change the boot lid....I'm getting excited :D
IMPI
Post by IMPI »
Found another few parts for the car.
As the oil cooler is to live under the nose I needed an apron with vents.
I aim to replace all suspension bushes etc with new and will only then considder aftermarket as I am not a fan of urethane I would rather make bushes from vesconite if need be
66looker
What model do you have?: 1966 bug
Post by 66looker »
:hangloose: nice armand looks like the pieces are coming together!
'HE WHO KEEPITH HIS MOUTH KEEPITH HIS LIFE'
splitfan
Has thanked: 46 times
Been thanked: 26 times
Post by splitfan »
:( sniff.... :cry:
IMPI
Post by IMPI »
I decided to treat myself to some work on the car an decided to fit the steering rack as it is one of the areas I dreaded (surfing the net netted very little info except that it was possible to fit a Passat rack.
lloking at Phots yielded an approximate position and some 100 by 50 square tubing was used to make the brackets. I also had to cut the body open in order to ad captive nuts
Nice job, looks perfectly fit and close to the pan. I'm guessing you aren't going to low otherwise the rack might hit the ground?
IMPI
Post by IMPI »
The rack is positioned as close to the std late beetle position as I could judging from Photos It is als actually above the tunnel so wont be the lowest point in the car I will be lowering the car but it will not be a "pan scraper" handling and very little bump steer is the ultimate aim.
Has thanked: 19 times
Well A small Update on BENZIN
The IRS Transmission is built
A Stage one Buggerd :lol: Transmission
Some info inside the Box
TIPH old school 4 Spider Super diff
Ally HD side cover
Other diff cover We used a HD Factory cover plate as they are also very strong and were only found on a few IRS Transmissions here in SA
Special import Syncro rings
Coarse Gears on 3de and 4th and Welded to the Hubs to take some Power with out spinning off the Hub
4th Geatr is a Longer Ratio as well for nice croozing capabilities
Gear carrier Shafts Re bushed
Steel selector fork on 1st and 2nd as most have Brass selector forks
Steel Cage roller bearings
And a few other hidden tricks in side theTransmission which will mazke it Reliable to take around 160Kw on the wheels
Have already wrapped the Trans butwill take a pic of it as is and load it later
