Also decided it was time to replace the headlights, as the original ones are now royally stuffed (one pointing upwards, the other sideways). So ordered these from Cip1
and some new cool blue bulbs
Care to explain preferably with pictures the Dash repair process of the vents...the cold air is getting to me also.windtramp wrote:glued foam to air control plates in ventilation box, re-assembled the unit and installed it ... BLISSS no more cold air "blasting" in thru the dash airvents at 0630 in the morning !!
also reglued foam to those flat plates/valves in the floorwell vents, reassembled the cleaned, repainted re-foamed contraption, and installed back in car .. magic .. no more frozen feet either.
if i cant get the heater to work i can now at least keep the cold air out .. progress
BlitzkriegBlitzkrieg wrote:Went to Pro Auto rubber to buy fender welts and fuel hose. Also had a look at their sound deadening products.
Then went to go and buy a Facet fuel pump. And a few other odds and ends too.
I'm going to be very busy this weekend. Starting from this afternoon, no opening world cup game for me
R14-00inc per metre, quality is very good too.@ndrew wrote:BlitzkriegBlitzkrieg wrote:Went to Pro Auto rubber to buy fender welts and fuel hose. Also had a look at their sound deadening products.
What did you pay for the Fender welts if i may ask?
Blitzkrieg wrote:R14-00inc per metre, quality is very good too.@ndrew wrote:BlitzkriegBlitzkrieg wrote:Went to Pro Auto rubber to buy fender welts and fuel hose. Also had a look at their sound deadening products.
And they have it in White too, for those vintage look Beetle/Type 3 guys
