When I was co Owner at Beetle inn from 2000 and we wanted to get as much Exposure to the company We decided to buy a new Beetle for advertising
And it did work we got invited to a host of shows to show off our cabriolet bugs with the New one
There were a waiting list of quite a few months but a friend of ours pulled a few strings and we got a black bug and hence from the beginning it was Called The Black
Jokingly was also called Lucifer hence the Registration plate LCF
I started with the VR project in 2003 just before I ended my Partnership with BI
My ex partners carried on with the project but with very bad luck and less success they managed to fit the motor,Although I think much help was recieved from 3de party companies
This bug was as the story goes through different EFI systems,bigger injectors 2 turbos and 3 damaged motors.
I was phoned 2 months ago to help and Collect the bug and was standing at my property since
we collected the Bug from the guys that was supposed to just set the EFI maps nice and rich for running inn purposes but Have managed to damage the motor again on the Dyno.
Motor spinns like no spark plugs present
The bug has been fitted a Body kitt and resprayed to a very low standard
I will be removing the whole conversion and start from the beginning and check out where the problem areas is
This project will be in the back of the Que for now as I have a few others waiting patiently for the right time for them to be in the front of the Que
I think this is the only one in SA that I know of if youknow of others pls let me know about them
Here are some pictures
