66 Feuerwehr Project
Re: 66 Feuerwehr Project
The bottom one is 100% like mine out of my Brassillia. Even the colour is the same. :D
Has thanked: 19 times
Testing Rotiserie for strength and DOES IT WORK??
Had to roll the bus out of the Garage as it would ave been to high if I loaded it on the trailer in the Garage even with my Garage door opening at 2.7m
Rolled to the side so to inspect the bad rusted roof
Given the under body its first sunlight since birth as I don't think this bus has seen this view before :lol:
After one hell of a mission we managed to get it on the trailer
I first tried rolling it on but would have damaged the sides of the bus
Then used tressels and bit for bit lifted it higher and pulled the trailer underneath and the same way down again
Now it is awaiting the trip to the sand blasters and I cant wait to see what is left of the bus after blasting
Hope there is metal left to work with
GavinHuart
Has thanked: 48 times
Been thanked: 9 times
Post by GavinHuart »
WOW Pierre! That rotisserie is seriously cool! Must have been a hell of a struggle to get it onto the trailer. Well-done! :hangloose:
Man alive ! Well done dude ! Hope all goes well at the blasters and that it turns out to be not-too-bad :D
Well Done. :hangloose:
Rotiserie looks very cool. Maybe you should send the design to one or two mines rolling splitties down hilsides :twisted:
BUGGOFF
Post by BUGGOFF »
Great stuff pierre, how difficult is it to actually get it rolling?
BUGGOFF wrote:Great stuff pierre, how difficult is it to actually get it rolling?
Actually not difficult at all only at one certain spot it wants to roll back from where it was rolled but that is why the safety bar is to keep it from rolling back
It was quite funny rolling it out of the garage hearing all the loose stuff (RUST) falling around
BUGGOFF
Post by BUGGOFF »
Haha, ek kan imagine. kewl.
Sambabus
Short Block
Has thanked: 39 times
Post by Sambabus »
I know of a place that has all the fire stuff you looking for,...but the manager of the storage yard is a prick!...call me if you want the details.
Sambabus
Short Block
Post by Sambabus »
lowlight
Post by lowlight »
Bly Jy het reggekom.
Must give credit to Lowlight and Fig who directed me to the rotisserie threads on the Samba for drawings and pictures :hangloose:
I actually might have a surprise in the pipeline have my Eye on a running Fleetline panel van
Even If I buy it I will continue with this project slowly as I will have a mobile bus for measuring and building stuff and use it in the
Fleetline in the mean time till the 66 is built then sell the fleetline
Question
Is the inside measurements of a 66 German Panel and a Fleetline panel the same
I know the back tailgate sizes differ
I want to use the Fleetline for template building Camping interrior bed etc and then must be removable perhaps to transplant to
The Feuerwehr project ? :?:
Apart from the area around the rear hatch, a Fleetline is identical inside to a 66 split bus.
I once built a removeable camping kit for a Fleetline panel that was locked in place by two wooden wedges. Knock out the wedges and the whole interior came out in seconds.
Good :D
Then I can use the Fleetline as a template
Well while thinking about the "Fleetline" on the way to collect the mind gears started spinning as the back tailgate was narrow and the door handles were fleetline pull type,but remember the front Badge panel did not have the Fleetline type pressed VW badge but a small Bay window type and nipple type front indicators then I called the Fig and spoke to him and then we discovered that it was in fact a late 63 model as the vin number is 1130335
Which is even better as I got a older bus than I thought :D
The Idea with the 63 is to drive it as is and carry on with the rebuild of the 66Feuer till the Feuer is driving and then probably sell the 63
The 63 just had the motor serviced by Vee motors by the PO but they did not do anything to the brakes as he did not wanted brakes done but just get it running as the previous time 6 months ago he drove it he got stuck with the bus. So He just wanted it mobile and that was where I heard of the bus that was for sale and made the PO a offer which he accepted and still paid for the service of 2.5K
He collected the bus from Vee and drove it to my spot
The vrou Kid and I went for a spin later this after noon and the left front wheel nuts came out and the wheel came out and did some minor damage to the dog leg :bn: :bn: :bn: and some other words I utterd
Phoned Vee but was told the Po did not wanted to have any brake work done so the wheels was not taken off which was convermed by the Po. So It was just murphys luck when we went for a spin
But hey here are some pics
The PO also only had it for around 1year or less Have any of you guys got info re the Previous, Previous owners or history on the bus :zhelp:
:hangloose:
