My early volkspares/vw(?) buggy
tony777
What model do you have?: T25 van
Facebook: http://www.facebook.com/home.php#!/profile.php?id=15007
Post by tony777 »
before i post here, I would just like to say that this is my first build ever, and your critisism would be greatly appreciated.
Im now 22 years old, studying to be a mechanical engineer so it was quite a nice project for me :)
okay, I'm back posting so i will try do this in the correct order :)
right in the beginning, i aquired a buggy, and almost three beetles worth of spares in boxes and figured.. ahh, it cant be too hard!!
rebuilt the suspension, had the chassis powdercoated
Proceeded to rebuild my 1600 next, and the spec list is pretty big..
> Scat counterbalanced 8 dowel crank
> 1 size over pistons (tried to keep lots of meat on the sleeves)
> gas flowed heads myself at anthony taylor developments, 44mm inlet, 35 outlet if memory serves
> ford v6 cam profile
> Empi windage tray
> high volume oil and petrol pump
> external oil filter and extra-sump
> alternator
> etc etc etc :hangloose:
bought the 17" rims to fit the all round disc'd buggy
bought and fitted the new tyres
slowly started building the cage myself out of 2mm seemed piping
just another two pics of the buggy as she was, then.
a little further on the roll cage
cage finished, body off, cage fits back on
just another shot of the cage on the chassis
freshly painted body
some more pics of body drying
then, there is a bit of a gap in my pictures, but here is what she looked like on the first drive..
DR WATSON
Has thanked: 7 times
Been thanked: 4 times
Re: My early volkspares/vw(?) buggy
Post by DR WATSON »
Your buggy looks amazing :hangloose: Still the best shape buggy ever designed :deflag:
hendriks
Been thanked: 13 times
Post by hendriks »
Wow, looks great!!!
tony777
Post by tony777 »
thanx guys. been working on her for long enough now!! just gotta try get the suspension sorted out now, the tyres keep rubbing
Warren G
Post by Warren G »
Wow your buggy looks good :hangloose: love the white
Been thanked: 21 times
Post by Ron&Gill »
Very nice.
Yes, I was going to say the same... you need to stiffen up the rear suspension a bit. There are threads here that tell you how. There's some trickery to it with respect to saving your fingers and the sequence of tightening it up after adjustment.
Still... very nice
splitfan
Has thanked: 46 times
Been thanked: 26 times
Post by splitfan »
Well done on the build , it looks great.
John Alves
Has thanked: 3 times
Been thanked: 48 times
Post by John Alves »
Great stuff, you gotta get a 4 into 1 exhaust, you wont regret it
1958 1600 TP Karmann Ghia
1968 1600 TP Beamish buggy
1968 1500 SP Beetle
tony777
Post by tony777 »
Haha :) i like the 4in1, but i use the buggy extensively off road, so clearance is of utmost importance to me. Also, the cage at the back i made when i made the rollcage, and as a result the 4in1 doesnt fit :(
Also, @ Ron@Gill, i dropped the rear one spline on the outside a while ago, now i must just push it up one click on the inside. Im just trying to decide whether im going to go that route or the coilover route. Hence i have yet to adjust properly.
Hi Tony, congrats on a beautiful buggy! :hangloose: I really admire your creativity and dedication - it shows clearly in the end product
tony777
Post by tony777 »
thanx Pine, appreciate it :)
Klaus
Post by Klaus »
Awesome buggy - really like the older styling shell and good work on the cage :hangloose:
looking at the picture, you can see the suspension was dropped... if you reverse the drop, you will prob find your camber is closer to where it should be and that your tyres dont rub anymore.
I was eyeing out those BF Goodridges yesterday at TWT... looks good on a buggy!!!
Nice project though, very nice.
tony777
Post by tony777 »
@ Tony Z - yeah at this point i dont think i had any dampers in either. i sourced old motorbike coilovers and put them in which worked fine, ride height is just where i wanted it, but the damping is unfortunately too weak. this means that standing still she is perfect but the second the buggy hits a bump, the wheels go in too easy. busy hunting for something similar with stronger damping. all im worried about moving her back to standard setup is that dreadedpositive camber look..
as for the tyres, yeah they are great, but i feel like im running out of power with them. I have a 1300box, which should help for the ratio's but she still feels a little sluggish. next thing, once she has been run in properly, is to look for a 36 downdraft and replace that silly solex :P maybe then she will feel better.
Hloni
Has thanked: 14 times
Post by Hloni »
Tony, a lekker build man. Tell us more about your cage, why the particula design (particularly towards the rear), and have you got more build photos of the cage?
I am building a buggy and first thing on my mind is a cage - style, pipping, etc. I am though building a lwb, so a tad different too.
Pine, are there any 'off the book' cage designs one can get a hold of, especially for a lwb?
:hangloose:
3011
