im sure this thing is going to rev....like a monster two stroke.....considering the weight of the flywheel...
Lag? What lag??? Bwahaha bwahaha
2 liter Type 4 efi turbo in the works
- Dazz
- Oil Cooler
- Has thanked: 2 times
- Been thanked: 4 times
Re: 2 liter Type 4 efi turbo in the works
Measure twice CUTonce.
1975 Kombie
1979 Kombie
W203 C320 CDI
'68 Austin Cambridge A60
Looking for a kombi project
1975 Kombie
1979 Kombie
W203 C320 CDI
- What model do you have?: 1970 Bug
Thanks! I´m aiming for 450.The hardware is capable of it,the rest is proper tuning which will be the biggest challenge..Cool I love the Type 4 motors
What HP are you looking at making
Should make more than 275HP ?
The Flywheel is the only thing that has really been lightened.I do want it to rev quickly but I don´t want a really nervous engine either.It´s a comprimise also to reduce lagim sure this thing is going to rev....like a monster two stroke.....considering the weight of the flywheel...
- Dazz
- Oil Cooler
im so anxious to see a clip of this ''MACHINE'' running through its gears....Once its run in.
1975 Kombie
1979 Kombie
W203 C320 CDI
1975 Kombie
1979 Kombie
W203 C320 CDI
Thanks Dazz,
it will be a little while though.The next major thing is a bug transmission that will take the power.It won´t be a drag racer,I´m wanting to run it on road races and circle track like Hockenheim or Nurburgring.Just for fun,though and the occasional race.
BUGGER TRANSMISSIONS !!!!!!!!!!!!!!!!!!!!
- Dazz
- Oil Cooler
70Turbobug wrote:Thanks Dazz,
Nurburg....should be awsome. It would be awesome to see what it would be able to do around the nurburg in the hands of Sabine Schmidts....
1975 Kombie
1979 Kombie
W203 C320 CDI
1975 Kombie
1979 Kombie
W203 C320 CDI
- beetlefanatic
- Has thanked: 8 times
- Been thanked: 12 times
Ooooooohhhhhhhhhhhh Sabine!
She got a bit on my nerves in the Euro version of 5th gear, though.
- buggyfan
- Long Block
- Has thanked: 95 times
- Been thanked: 87 times
http://Www.buggertransmissions.co.za70Turbobug wrote:Got a link?
Only drawback is youre in GERMANY and he's in GERMISTON,South-africa
That´s true.Thanks for the link I will look into it! They would have to be either much cheaper or the freight costs would have to be much cheaper.Generally it´s the freight costs that kill.It´s the same ordering from the USA also.On top of that I have to pay import tax which is 23,5% including freight costs and the price of the gearbox
.So usually it´s not any cheaper buying out of country.However, companies like KCR or Rancho build better gearboxes than what is usually available here in Germany.I don´t want to go with a Porsche gearbox unless it´s a first generation G50 (from the ´85 911 SC 3.2 ).But that means modifying the floor pan and I don´t want to do that because I want to get this thing done finally..The bug has been in parts for 10 years and I´ve had a lot of set backs within this project and I want to get it done this year - hopefully.
