hi. just bought a accuspark electronic distributor for my bus (1970 t2a) and will have to re-set the timing, problem is, here in england theres nothing in the haynes workshop manual for this code only the following
"ad series engine to number 290 640 = 5 degree's atdc"
"ad series engines from number 290 641 = 7and a half degree's btdc"
"ae series engines 5 degree's atdc"
ive had a look on here and google for any info on fcr code but no luck.
the engine in it is a 1.6 twin port.
has anybody on here got any ideas what the setting should be ?.
cheers and all the best, chicargo
timing for FCR160*** engine code
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 322 times
Re: timing for FCR160*** engine code
The timing is determined not by the engine number, but by the distributor you are using. If your new dizzy doesn't come with any instructions re timing, then set timing so that it is no more than 29deg BTDC at full advance.
SFCR prefix signifies an engine assembled in South Africa on a Mexican or Brazilian universal case.
- fig
- Bus Driver
chicargo
- What model do you have?: vw t2a deluxe kombi
fig wrote:The timing is determined not by the engine number, but by the distributor you are using. If your new dizzy doesn't come with any instructions re timing, then set timing so that it is no more than 29deg BTDC at full advance.
cheers for the info, i managed to sort it now. installed the new dizzy and seems to be running a lot better now. all the best, chicargo
chicargo
do not leave your ignition on if the engine is not running - you will burn out your ignitionchicargo wrote:hi. just bought a accuspark electronic distributor for my bus
always carry a spare (stock) points and condenser or a spare accuspark module in case you burn yours out
these are fantastic while they work, but be warned, they burn out for no reason at all. Trust me, I have done about 8000km with them, first one lasted 4500 km. Last 3 lasted about 80km. One of them didnt even last long enough to start the engine.
chicargo
cheers tony z, lucky you told me not something i would have thought about. i really do hope they dont burnout as i'm getting a bit sick of having to phone up the aa all the time to come and pick me up every time i use my bus.Tony Z wrote:do not leave your ignition on if the engine is not running - you will burn out your ignitionchicargo wrote:hi. just bought a accuspark electronic distributor for my bus
nice one fella. all the best, chicargo
