You can ask for the fleetline/ 67 model. the 68 got a diffrent handle
this is the ones that the fleetline uses left and right.
http://www.wolfsburgwest.com/cart/Detai ... 211837205D
http://www.wolfsburgwest.com/cart/Detai ... =113837205
this is the one you need.
http://www.wolfsburgwest.com/cart/Detai ... =113837206
http://www2.cip1.com/ProductDetails.asp ... -837-206-D
I think it will fit left or right.
Does your driverside 's lock stil working& lockable?
'75 Fleetline SC splittie Wide loadbed
- sarel.wagner
- Pushrod
- What model do you have?: T1 x 4, Split SCwide
- Facebook: http://www.facebook.com/sarel.wagner
- Been thanked: 2 times
Re: '75 Fleetline SC splittie Wide loadbed
Done a few things
Replaced the mirrors, now need a long door hinge mount mirror arm, anybody? Replaced the gear shifter plate and the rear coupler. Me thinks something is bent as the shifter is adjusted according the manual, but it still dislocates, time for another disassembly
Replaced the headlights as one had a beetle glass in. Both were actually LHD units, from Mexico or Brazil most likely. Also replaced the lost air vent handle and reinstalled the proper inner door handle, the roll pin was missing.
Rgrds
Rgrds
What other people think of you is none of your damn business
- jolas
- Has thanked: 393 times
- Been thanked: 173 times
Hi Sarel, nice work. My wide-bed SC came with standard size mirror arms, but no mirrors. I think it may have had truck mirrors or some other aftermarket mirrors fitted. I am interested in the fact that you want longer mirror arms, are the standard round mirrors/mirror arms not adequate due to the wide bed? What mirrors were on the SC when you purchased it ?
Would "elephant ear" mirrors work for you ?
Cheers
Paul
Cheers
Paul
- sarel.wagner
- Pushrod
Paul,jolas wrote:Hi Sarel, nice work. My wide-bed SC came with standard size mirror arms, but no mirrors. I think it may have had truck mirrors or some other aftermarket mirrors fitted. I am interested in the fact that you want longer mirror arms, are the standard round mirrors/mirror arms not adequate due to the wide bed? What mirrors were on the SC when you purchased it ?
Cheers
Paul
Thanx Paul. It only had one mirror fitted, the round style. The mirror that was on there had the longer arm to clear the wide bed, standard length arms don't work. I got the 2 new round mirrors and the clamps, only looking for one longer arm.
Also still looking for the LH outer door handle....
Rgrds
