Drop Front suspension on H-Beam
tigs79
- What model do you have?: oval window beetle
Hi guys, I'm looking for someone that can drop the front suspension on my type 1 H-Beam
- 1972
Re: Drop Front suspension on H-Beam
Give Bugger a call...his number is all over the site. (ad banner at the top of the page)
- beetlefanatic
- Has thanked: 8 times
- Been thanked: 12 times
Splitfan also does it. I think he supplies the adjusters as well.
- Has thanked: 19 times
- Been thanked: 58 times
tigs79 wrote:Hi guys, I'm looking for someone that can drop the front suspension on my type 1 H-Beam
Thanks 1972
tigs are you going to remove and strip the Hbeam yourself
or do you want me to do the whole thing remove strip cut fit adjusters re assemble and refit hbeam
- bugspray
- Floorpan
- Has thanked: 24 times
- Been thanked: 16 times
Bugger and Splitfan please pm me the cost involved to lower the beam ON the vehicle ie remove,fit, replace. Thanks.
tigs79
Hi Pierre,
I have it out the car stripped already, like to get it dropped before I spray and do some detail to it. I would only bring the H beam to you
- Dark Cloud
- What model do you have?: 1973 Beetle 1600cc
- Has thanked: 13 times
- Been thanked: 5 times
Hello everybody
Bugger, how much would it cost to "do the whole thing remove strip cut fit adjusters re assemble and refit hbeam"?
- riaanj
- Has thanked: 6 times
- Been thanked: 41 times
Ditto on Dark Cloud's reply....
Just keep on BUGGIN'
T6 Ranger 2.2TDCi D/Cab
307E Anglia panel-van
Honda CBR600RR
Honda CBR600F4
Honda CBR600RR
Honda CBR600F4
HI
Sorry for late reply
Adjusters x 2 R+-580
strip/Cut and weld replace blades springs R600
Remove and fit front suspension about +-8hrs R 1200
Gries R200
If you strip out the H-beam and just bring the H beam then I charge R400 to cut and weld both Adjusters in to the H Beam
so you can save quite alot on labour
When I weld the adjusters in I turn them slightly as to drop the bug already and put the adjuster in the center so you can adjust slightly up and down
Gries R200
- riaanj
Cool thanx Bugger, one question from my side, I see in the magazines they refer to narrowing the beam, most the time 2-4 inches, can you do that too? or is it too much of a mission with the blades(they must most probably get shortened too?)
Honda CBR600RR
Honda CBR600F4
Honda CBR600RR
Honda CBR600F4
HI No I dont do it that is for when you want to go very low and have the wheels tucked in very deep
Think Splitfan does the narrowing of the h beams
- Dark Cloud
Hi
Bugger, your prices are really reasonable. It's better than purchasing a brand new adjustable beam. Will bring my beam towards November. Thanks
Your the best!
Your the best!
- Hloni
- Has thanked: 14 times
- Been thanked: 11 times
Bugger, do you also do the rear i.e. bring cab to you and get it back a week later with a dropped back suspension? Oh...when the rear is dropped, what shocks are fitted onto the bug?
- riaanj
Cool thanx Bugger, your help is greatly appreciated!
Honda CBR600RR
Honda CBR600F4
Honda CBR600RR
Honda CBR600F4
