Bug Aircon
- 65beetle
- What model do you have?: 1965 Beetle
Bug Aircon
Hey guys.
Has anyone seen these aircon units? if so, hows about some background info. Saw this article at this link http://www.cardomain.com/ride/2411437/1 ... gen-beetle and was wondering how many of these there are around. would be awesome to get a unit for my bug resto.
- rouxlouis
- What model do you have?: 1977 SP1600
- Facebook: http://www.facebook.com/#!/paul.l.roux
- Has thanked: 14 times
- Been thanked: 5 times
Re: Bug Aircon
Dude, if you do find out, pls let me know where.
Getz damn hot where I stay in summertime!
- bugspray
- Floorpan
- Has thanked: 24 times
- Been thanked: 16 times
Re: Bug Aircon
Will be a schweet mod. But what about additional strain on the already taxed engine??
- fleetline15
- What model do you have?: 13 window 63 15 wind
Re: Bug Aircon
best air con solution is do a subaru conversion first!
LOL
Seriously though I have seen a couple in Australia . The modern rotary compressors are they way to go they are much more efficient and less taxing to your donk. . Mitchell
LOL
- fig
- Bus Driver
- Has thanked: 287 times
- Been thanked: 322 times
Re: Bug Aircon
I don't think aircon on an ACVW will be very successful. The 1600 ACVW cooling system was marginal and power output doesn't exactly leave a huge reserve for compressors and such. There's a reason why you don't see aircons on ACVWs in SA.
Think about it, in HOT weather (when your engine is already struggling to keep cool), you want to add more strain on the engine (ie, more heat generated), as well as a whole lot of extra stuff that needs cooling under there. Sounds like a recipe for short engine life to me ...
- 65beetle
Re: Bug Aircon
Good point fig, I didnt think about that. I see in the article the guy says
Louis, if i find 1 il let you know...
Why would the drivers side condenser have a fan on it and not the passenger side. It seems a lot of people wouldn't mind getting their hands on a unit like that. Do you think if you built an power plant with a large sump it would help with cooling if it has an aircon unit to drive.These are the two condenser coils for the air conditioning system. They are located underneath the car, on either side of the transaxle. The one on the driver's side has a 6 volt electric fan to assist w/dissipating heat.
Golfmad, tell us a bit more about an O V T 100 system plsGolfmad wrote:Post by Golfmad » Thu Jul 28, 2011 8:01 am
O V T 100 system, workes fine, little or no power needed from the engine....
- Been thanked: 541 times
Re: Bug Aircon
Very true what FIG said......
But he forgot to add that VW foresaw this problem,
and built in a " LEDD" Air conditioner system,
"Low Energy Draining Device" to cool the car without over heating the engine.
All Vw's have had these systems included into the build, since the development of this unit.
Can not remember as from which year this was included.
But should you look at your Drivers manual, you should be able to pick it out.
Also have an instruction on how to use it.
Just look in the index under...
"WINDOW" .
Hope this helps
"WINDOW" .
Hope this helps
- Sambabus
- Short Block
- Has thanked: 39 times
- Been thanked: 14 times
Re: Bug Aircon
I never get hot in my bus,.....only when im standing still,the wind pumps through the vent windows and through what I like to call the ram air air conditioniong duct of fury that busses came out with.
But like all good things,it comes at a cost,I have to hold the window open with my hand,which leaves me with the strangest trucker tan you have ever seen!
- Golfmad
- Has thanked: 4 times
- Been thanked: 9 times
Re: Bug Aircon
O V T 100 system explained - Oop Venster Teen 100 kph.65beetle wrote:Golfmad, tell us a bit more about an O V T 100 system pls
Re: Bug Aircon
at a guess the one without the fan is the condenser and the one with the fan is possibly the evaporator....65beetle wrote:These are the two condenser coils for the air conditioning system. They are located underneath the car, on either side of the transaxle. The one on the driver's side has a 6 volt electric fan to assist w/dissipating heat.
- splitfan
- Has thanked: 46 times
- Been thanked: 26 times
Re: Bug Aircon
My solution
- Has thanked: 45 times
- Been thanked: 208 times
Re: Bug Aircon
Think both units next to the transaxle are condensers. With 6V and only around 180W of generator power they probably only had enough power for a fan on one condenser. Two would have been better. Remember that the evaporator under the dash also has a fan, and the clutch on the compressor has a solenoid that also needs power.
