Bug Aircon
65beetle
What model do you have?: 1965 Beetle
Bug Aircon
Post by 65beetle »
Hey guys.
Has anyone seen these aircon units? if so, hows about some background info. Saw this article at this link http://www.cardomain.com/ride/2411437/1 ... gen-beetle and was wondering how many of these there are around. would be awesome to get a unit for my bug resto.
rouxlouis
What model do you have?: 1977 SP1600
Facebook: http://www.facebook.com/#!/paul.l.roux
Has thanked: 14 times
Re: Bug Aircon
Post by rouxlouis »
Dude, if you do find out, pls let me know where.
Getz damn hot where I stay in summertime!
bugspray
Floorpan
Has thanked: 24 times
Been thanked: 16 times
Re: Bug Aircon
Post by bugspray »
Will be a schweet mod. But what about additional strain on the already taxed engine??
louisvr45
Re: Bug Aircon
Post by louisvr45 »
would love to do this on a splitty
fleetline15
What model do you have?: 13 window 63 15 wind
Re: Bug Aircon
Post by fleetline15 »
best air con solution is do a subaru conversion first!
LOL
Seriously though I have seen a couple in Australia . The modern rotary compressors are they way to go they are much more efficient and less taxing to your donk. . Mitchell
Re: Bug Aircon
I don't think aircon on an ACVW will be very successful. The 1600 ACVW cooling system was marginal and power output doesn't exactly leave a huge reserve for compressors and such. There's a reason why you don't see aircons on ACVWs in SA.
Think about it, in HOT weather (when your engine is already struggling to keep cool), you want to add more strain on the engine (ie, more heat generated), as well as a whole lot of extra stuff that needs cooling under there. Sounds like a recipe for short engine life to me ...
Golfmad
What model do you have?: niks
Been thanked: 9 times
Re: Bug Aircon
Post by Golfmad »
O V T 100 system, workes fine, little or no power needed from the engine....
65beetle
Re: Bug Aircon
Post by 65beetle »
Good point fig, I didnt think about that. I see in the article the guy says
These are the two condenser coils for the air conditioning system. They are located underneath the car, on either side of the transaxle. The one on the driver's side has a 6 volt electric fan to assist w/dissipating heat.
Why would the drivers side condenser have a fan on it and not the passenger side. It seems a lot of people wouldn't mind getting their hands on a unit like that. Do you think if you built an power plant with a large sump it would help with cooling if it has an aircon unit to drive.
Golfmad wrote:Post by Golfmad » Thu Jul 28, 2011 8:01 am
Golfmad, tell us a bit more about an O V T 100 system pls
Louis, if i find 1 il let you know...
Re: Bug Aircon
Very true what FIG said......
But he forgot to add that VW foresaw this problem,
and built in a " LEDD" Air conditioner system,
"Low Energy Draining Device" to cool the car without over heating the engine.
All Vw's have had these systems included into the build, since the development of this unit.
Can not remember as from which year this was included.
But should you look at your Drivers manual, you should be able to pick it out.
Also have an instruction on how to use it.
Just look in the index under...
"WINDOW" .
Hope this helps
:lol: :lol: :lol:
65beetle
Re: Bug Aircon
Post by 65beetle »
HAHAHAHAHA :lol:
Thanx Herman
Sambabus
Short Block
Has thanked: 39 times
Re: Bug Aircon
Post by Sambabus »
I never get hot in my bus,.....only when im standing still,the wind pumps through the vent windows and through what I like to call the ram air air conditioniong duct of fury that busses came out with.
But like all good things,it comes at a cost,I have to hold the window open with my hand,which leaves me with the strangest trucker tan you have ever seen!
Golfmad
Re: Bug Aircon
Post by Golfmad »
65beetle wrote:Golfmad, tell us a bit more about an O V T 100 system pls
O V T 100 system explained - Oop Venster Teen 100 kph.
:lol:
Re: Bug Aircon
at a guess the one without the fan is the condenser and the one with the fan is possibly the evaporator....
splitfan
Has thanked: 46 times
Been thanked: 26 times
Re: Bug Aircon
Post by splitfan »
My solution :wink: :wink:
Has thanked: 45 times
Been thanked: 208 times
Re: Bug Aircon
Post by Dawie »
Think both units next to the transaxle are condensers. With 6V and only around 180W of generator power they probably only had enough power for a fan on one condenser. Two would have been better. Remember that the evaporator under the dash also has a fan, and the clutch on the compressor has a solenoid that also needs power.
