Dolf Jonker
Posts: 35 Joined: Fri Jan 14, 2011 9:40 pm
What model do you have?: 1967
Post
by Dolf Jonker » Mon Jan 24, 2011 10:05 pm
Hi
Herewith some progress on the restoration of my 1964 "TOY"
. No rust and no body filler restoration.
Furthermore the '67 Splittie
will be going in for bead-blasting Saturday 29 Jan '11.
Dolf
Dolfino
Phillip
Posts: 238 Joined: Wed Feb 24, 2010 3:30 pm
Post
by Phillip » Tue Jan 25, 2011 1:16 pm
Bonnet looks good,,,,or is it a fender...
...is it just me or are ur pics very tiny,,,blow them up a bit,wanna see what u doing...
Dolf Jonker
Post
by Dolf Jonker » Tue Jan 25, 2011 1:27 pm
This is the body shell. Will upload bigger photos later.
Dolfino
Posts: 8717 Joined: Mon Feb 07, 2011 8:51 pm
Has thanked: 425 times
Been thanked: 543 times
Post
by retrovan » Thu Apr 28, 2011 3:12 pm
Hi Dolf,
Its looking good.
Looks like us OKKIES in PE are going to show them how its done.
Herman.
67man
Posts: 68 Joined: Tue Sep 08, 2009 6:35 pm
What model do you have?: 67 vw beetle
Post
by 67man » Fri Apr 29, 2011 6:35 am
What etching primer will you be using on the metal, and what grit paper will you use to rough-up the surface before spraying your etching primer?
Dolf Jonker
Post
by Dolf Jonker » Fri Oct 07, 2011 2:56 pm
The rims were painted but had to do it over as perl white was on outside and clashed with the white wall tyres. Repainted again and looks better
Dolfino
Dolf Jonker
Post
by Dolf Jonker » Fri Oct 07, 2011 3:53 pm
Old floor pans were replaced with halves from Volkswarenhaus (Germany), bad service overall
Dolfino
Dolf Jonker
Post
by Dolf Jonker » Fri Oct 07, 2011 3:57 pm
Dolfino
Post
by retrovan » Fri Oct 07, 2011 3:58 pm
Hi Dolf,
Welcome back, was wandering how the beetle was going.
The wheels look good now, I think you did the right thing.
I take it the car is going to be two tone light green and perl white. ?????
How did the blasting go, did you get a good job done.
Dolf Jonker
Post
by Dolf Jonker » Fri Oct 07, 2011 4:01 pm
Dolf Jonker on Thu Dec 01, 2011 9:00 am, edited 1 time in total.
Dolfino
Dolf Jonker
Post
by Dolf Jonker » Fri Oct 07, 2011 4:04 pm
Hi Herman
Yes it's gonna be 2 tone as you mentioned. Sandblasting was a disaster, damaged the panels and redid all work manually again.
Dolfino
Dolf Jonker
Post
by Dolf Jonker » Fri Oct 07, 2011 4:06 pm
Dolfino
Dolf Jonker
Post
by Dolf Jonker » Fri Oct 07, 2011 4:09 pm
Dolfino
Post
by retrovan » Fri Oct 07, 2011 4:10 pm
Sorry to hear about the blasting, but the project is looking good.
Hey ... the "OU MAN kan nog ne!
You will have a excellent car there when done.
But please keep us posted, will only inspire others to keep going....
Dolf Jonker
Post
by Dolf Jonker » Fri Oct 07, 2011 4:13 pm
Yes was so busy with the actual work and did not have time to update.
I will post more photos in due time
Dolfino
