O and Bugspray, I know rubbing yourself with olive oil before sun tanning is meant to give you a nice golden tan, BUT you dont need it
What Oil To Use - one opinion- Warning- read heavy
- JamesD
- Been thanked: 20 times
Re: What Oil To Use - one opinion- Warning- read heavy
Thanks Rui, food for thought. I'm was planning on standardising my oils and brake fluids, guess i better actually check what Motul oils have in them before i put it in the Beetle.
and its rub on oil, not bath in oil
From fastest to slowest:
'75 SP 1600 with a few mods
- Wanda
- Oil Leak
- What model do you have?: 1971 kombi
Hi guys,
After reading all this (half of which just went far over my head), I still have a question. In an old engine, is it good to use products like Prolong or PS23? I was told to use SAE40, which I do. Will I prolong the life of the engine by also adding these types of additives, or will I be wasting my money(R199 a bottle PS23)? How often should that then be added? I have to top up my oil quite often.
