Retrovan's 1968 Fastback
Been thanked: 98 times
Portugal
Post by calooker »
Regulators don't like heat or vibration put it under the back seat where it should be
Has thanked: 424 times
Been thanked: 542 times
sean wrote:Congratulations on getting it started.
There is the original mounting point just to the left of the coil, or were you missing the original bracket?
Are the carburettors happy know or are there still issues?
Thanks, starting it was a great day.
No original brackets for the coil, but also very close to the engine lid, so I fitted it into the only recess that it will fit snugly into, the mounting is perfect where it is.
The carbs are working fine, will have to set, with air correction jets, as it is running a bit rich, want to change the air correction from 160 to 175, not sure where I can find them, but still looking.
IMPI wrote:Hi there cool mile stone
coil fits in std location on a type4 into type 3 as well
The regulator might not last there they were removed from the engine compartment for a reason
This stage has made it so great, feel like a little kid.
Thanks for the heads up Armand, as its my 1st transplant, I need to fit all 1st then move it around, then make it neat..... :lol:
As said above, did not have STD bracket, no holes were drilled or taped, as it was a 411 engine, and was also very close to the lid, so I fitted into the neat recess, fits nice, very happy with it, and runs cool as it takes the cooling from the fan... :)
The regulator is mounted there for the test run, is mounted on vibration and heat resistant pad, (see black under regulator) Now that the engine runs, the wiring has to be redone to a neat standard, the regulator can be extended, (wires were too short) to fit near battery. The wiring came with the engine, not made for type 3. :lol:
calooker wrote:Regulators don't like heat or vibration put it under the back seat where it should be
Thanks for the heads up, Rui, but as said, put it there as I had to get the wiring sorted out, as can be seen from all the long messy wiring.
As I am mixing, type 3 wiring with type 4 wiring, and type 4 motor in a type 3, all into a small area. Now that it is all sorted, the neatening can begin.
The regulator will move to the back seat, ones all wires are adjusted, but 1st , the TEST RUN.......... :lol: :lol: :lol:
Anybody have 175 Air correction jets for me please
Thanks guys, this project will not be possible with out your help.
Hi Guys,
After the last post's from you guys..........
sean wrote: ....There is the original mounting point just to the left of the coil, or were you missing the original bracket?....
IMPI wrote: ....coil fits in std location on a type4 into type 3 as well
.... Armand
Decided that you know best, and that I should make a bigger effort. so I worked out how to make the coil work in its rightful place.
Made an angle drill thingyamabob, and drilled the hole on the mount bump. was hell but who cares, then tapped the hole 5 mm, had to grind the coil bracket down on the sides to fit into the slide end of mount, placed bolt with two fender washers, on newly taped mount point, and bolted down the coil bracket.
NOW I can also say that the coil is mounted in the "original place" :D :D :D
Thanks guys. :wink:
Not happy with the carbs, don't get me wrong, it runs well, but it is still running rich.
So I contacted Calooker, and sure enough he came through, as always.
Managed to get me 2 sets of service kits for my two sets of twin carb's.
Also got me a full set of new and next size jets, so now I can set up the carbs to run perfect.
Hope to have the parts in my grubby hands in the morning.
In the mean time I have started to clean up the wiring, made a wire rout and support.
Moved the voltage regulator to under the back seat.( thanks to all :wink: )
Will now RENEW both sets of carbs, tomorrow, test both on the engine, and store one set for the ........OOooops!!.. nearly let it slip........ :oops:
Hope to have excellent news in the morning.
Till then.
Received the service kits today from Calooker, excellent service, thanks Rui.. :D
Reworked all the carb's, and fitter & tested them in the car.
All working perfect, now I am happy.
Went about fitting the voltage regulator into the space under the back seat, and that is where my :bn: started. :shock:
With the wires extended, I could not get the bloody thing to work right, reduced the wires back to the original wire harnes length, and then it worked correctly.
So now I fitted it under the engine lid, to the body, out of the way, man am i glade that work right again..... :roll:
Having cleaned up the wiring, I started fitting the bus filter box into the Fastback.
the dust box had to be reduced in hight, so that it would fit into the engine compartment, with lid closed.
Here is the dust box before modification.......
And here it is after modification....( in hight)....
Here is the engine bay before fitting the filter box.......
And here the filter is fitted......
Now I can hear the two schools of thought shout loudly........
Where is the Bling.........
OR Why not back to standard....
Well I want to have it look near normal, and should the average Joe look at it, he would not know the engine is not correct and that the type 4 does not belong there.
Well the upholstery is next , after test drive.......... :mrgreen:
Till then
Nice work Herman,but please also change the colour of the engine to red. That turquoise just looks wrong! :lol:
beetlefanatic wrote:Nice work Herman,but please also change the colour of the engine to red. That turquoise just looks wrong! :lol:
Thanks, but I kind of like the green, ...or is it blue, ....no wait its green, ....yes definitely blue, ... that's what I said. Green....
:lol: :lol:
Well the "Road" test went well, no arrests, no tickets, no points off my licence, .... the car ??? oh sorry :oops: No the car went fine, all gears work, no pulling to the side, the brakes work, no rattles, so I am very happy with the result, so now I will work to get it going for George 2012
Some pic's from return of road trip, note the "seat", and the "Rag trade" door locks. :lol: :lol:
Till next time.....
Doesn't the type 4 just have oodles of torque or what?! :D
Blitzkrieg wrote:Doesn't the type 4 just have oodles of torque or what?! :D
Best decision I made, fitting the type 4 2000lt to the Fastback,
As you say tons of torque, and best VW drive ever.
There is no better drive then the Fastback. Like a Cheap Rolls Royce.
:lol: :lol:
Yup best drive ever, drives even better than a Porsche 356 :twisted:
What are the bricks for????? ................................
Rear passenger simulation????????????????/ :lol: :lol: :lol: :lol: :lol:
By the way, I saw your new dash boards yesterday. They look very sweet. There is def. one on my list when I get my fasty going. And very easy to install.
Nice Work.
hitlers revenge wrote:Image
Witnesses....... :shock:
Don't you take yours with.....??
Would you believe Rear passenger weight simulation ..... :roll:
No stuck the back sound proofing down, and these "witnesses" are there to hold it down while the glue dries. :oops:
Has thanked: 235 times
Looking good! :hangloose:
Hard to believe it is the same car I dragged from the bushes six years ago, glad it found a loving home at last
hitlers revenge wrote:By the way, I saw your new dash boards yesterday. They look very sweet. There is def. one on my list when I get my fasty going. And very easy to install.
Nice Work.
Where did you see it, and was it installed, as I would like to have ALL the installed photos on the Dash thread, will look Cool.
:D
Thank you , was a lot of hard work, but they will make a lot of otherwise bad looking cars excellent, and valuable. Will make sure there is ONE for you when you need it.....
very easy to install, and the three options, will make the fit, to each guys own taste.
Now if only I could find one for myself.. :shock: ................ :roll: ................. :lol: :lol: :lol: :lol:
:wink:
