As most of you know I have a beetle with a 1.8 8v golf engine
![Image](https://www.aircooledvwsa.co.za/images/pbucket3/albums/r35/vuyo/side-1.jpg)
So I decided to turbo charge it so I got hold of a 1.9 Polo TDI turbo I don’t know what size it is but I estimate that it’s a T2?
bolts on to the head no neet for modz
![Image](https://www.aircooledvwsa.co.za/images/pbucket3/albums/r35/vuyo/P26-01-12_1257.jpg)
Its gong to be a blow through system , the charge is going to blow into a 36DRLA carburetor that’s turbo prepped
The biggest challenge I had to face was creating an inlet manifold to accommodate the DRLA , so I got 12mil thick aluminum plate and fabricated a flange and some 38 mil tubing to feed the carb into the inlet and got it all welded up.
![Image](https://www.aircooledvwsa.co.za/images/pbucket3/albums/r35/vuyo/P26-01-12_08081.jpg)
![Image](https://www.aircooledvwsa.co.za/images/pbucket3/albums/r35/vuyo/P26-01-12_08082.jpg)
![Image](https://www.aircooledvwsa.co.za/images/pbucket3/albums/r35/vuyo/P26-01-12_0814.jpg)
Space is an issue the throttle wheel needed some space so I cut out a little chunk out the bug
![Image](https://www.aircooledvwsa.co.za/images/pbucket3/albums/r35/vuyo/P26-01-12_1254.jpg)
![Image](https://www.aircooledvwsa.co.za/images/pbucket3/albums/r35/vuyo/P26-01-12_1255.jpg)
![Image](https://www.aircooledvwsa.co.za/images/pbucket3/albums/r35/vuyo/P26-01-12_1812.jpg)
Next step fabricate a turbo hat.
