Retrovan's 1968 Fastback
Re: Not 1967 but 1968 Fastback now with twin weber 2000cc mo
Yip if the clutch does not release properly it will cause the gears to grate so just set it lower and check it again
Well done son!
Has thanked: 424 times
Been thanked: 542 times
hitlers revenge wrote:Well done son!
Thanks Paa.
:lol:
So, after fitting the Weber's, and tuning the car as best as I could by means of two hoses to my ear's, with pieces that I chopped from my hose pipe. :oops:
The engine was running fine, like an OLD man's car should........ :shock:
Then I got into thinking, do I have the right Plugs in this "Altered Engine" ??????
With lots of questions to the right guys, as well as studying the plug manufacturers web sites, I decided to get me a set of plugs.
With every change off standard, you should cool down you plugs, or kill the engine.
So I changed to Not the std plugs that I have always used in my VW motors, but something that made sense on the NGK site.... :) , the NGK-R BPR7ESZ-N
Boy, what an improvement, the whole engine is not only crisp, but willing and instant response.
And NO, its not a hotter plug, but actual, its a cooler plug, that's why it works.
Then removed my front shock, to get two replacements in the morrow,......
Set up the clutch cable for full release.
Till next time....
herman
Well guys, its been a year, and then some, the :bn: hit the fan a few times, other times things went very well, BUT at last the Fastback is on the road, and driving well.
Went on the 1st outing today, for a 80 Km round trip breakfast, Ran like a dream, what a feeling to run the thing that you have worked on for so many hours, man this was great. :D :D
For the guys with 20/20 vision, (HR) you will find that the back storage compartment is still awaiting the carpets, the arm rests still await the arrival of the rest pillows from the Upholsterer. Also the under dash cover, Yes, they do not come out with them, but mine will have a white one, with a parcel shelf, ( note to Santa.....)
Well here goes, the Photos of the (more or less) completed 1968 Fastback :D
Well will let you know when she goes through roadworthy, and gets her new number plate,
Till then........... :wink:
8) Stunning Herman - well done :hangloose:
Wragtig Pragtig :D
69bug
Post by 69bug »
Nice job, Herman. Hope she gives many hours of pleasure
Mooi man. Looks very cool. Whats with the strippy paint work?? :twisted:
Can you post a closer pic. Showing the carbs. Just one side will do. Ans what carbs are they??
Thanks guys, I am sure with out all your help, this would most probably not have been possible. Thanks again ALL OF YOU. :wink:
Hey, HR, Did you not know stripes are in this year......... :lol: :lol:
Good paint job, :bn: camera.
What confuses the camera, is that there is very fine metallic in the final clear coat, which looks brilliant in the sunlight, but confuses the :bn: out of the camera.
Thanks for the compliment, I think..... :shock:
The carbs are twin 34 ICT Webers, work fantastic on the 2000 type 4. :D
Cool.Thanks, mine is running Dellorto's and I have a modified engine cover. Was wondering how you were using the original.
Obviously the dells are taller than the Webers.
Cheated a bit.
Got a set of short manifolds from Rui, skimmed them down a bit, and got supper thin cleaner.
still have the short Empi Manifolds here in the box.......
Also no heat spacers, also in the box...
Gerhard Volksie Bfn
What model do you have?: various
Facebook: Volksiemuseum gerhard
Post by Gerhard Volksie Bfn »
Looking good well worth the effort
volksieshop wrote:Looking good well worth the effort
Changed a bit since it left Bloemfontein,
Die plase nooi, became a stad's blommetie :lol: :lol: :lol:
Getting the fastback ready for RWC.
Lifted the back springs a bit, now its more horizontal, and looks less like a dog with broken back.
Had the drums cleaned, and fitted Newly re-bonded shoes.
Flushed the brake fluid line again, and set the brakes on each wheel.
Set hand brake.
Had to find the cause of the jumping speedo, Removed the cable, re-greased it, but found no fault.
Then I removed the speedo, and found the magnet drum axle was to thigh, striped the speedo, cleaned the shaft's, and re-greased it, re-assembled it, and yippy, it working fine. :D
Now I only have to set the head lights hight, and ready for the little guy with the big white coat, and little clip board, and big pair of glasses.
