Warwicks Split
Warwick-Lowlight
Re: Warwicks Split
Post by Warwick-Lowlight »
Will give the rims a cleanup and check all -just have to stop shaking
Muderick
Has thanked: 42 times
Been thanked: 69 times
Re: Warwicks Split
Post by Muderick »
Looks so Paul.... I called it a 61 as soon as Warwick sent us that MMS the other night !!! :lol:
Muds
Old School or Bust!
Stütz
Been thanked: 19 times
Re: Warwicks Split
Post by Stütz »
Warwick-Lowlight wrote:........ -just have to stop shaking
You know, that actually just gave me a lump in my throat! You deserve that car!
3104
Muderick
Re: Warwicks Split
Post by Muderick »
Use this you lucky chicken farmer! :D
"production year" should have a 1 in it, meaning 1961. Or else, confirm the numbers there?
The "23" under the "TYP" field confirms its a type 2 bus, and 3 -a 'kombi'
If its "234" it means: 2 -Type 2 / 3 - kombi /4 - Cargo doors left, right hand drive.
Muds
Old School or Bust!
Has thanked: 45 times
Been thanked: 208 times
Re: Warwicks Split
Post by Dawie »
Also think Jul-August 1961, probably assembled in SA around September that year.
The digit that identifies model year was first introduced end 64 for the 65 model year. Prior to that, it was only a plain sequential chassis number.
Muderick
Re: Warwicks Split
Post by Muderick »
Cool! So the 1st digit of the Chassis # should then be a 1.
Muds
Old School or Bust!
Warwick-Lowlight
Re: Warwicks Split
Rest of numbers as previous
Haven't cleaned rims but behind the spedo 3. 61
Warwick-Lowlight
Re: Warwicks Split
Plates
Volkswagenwerk AG
Made in Western Germany
23 Fahrgst NR 808593
This plate is at the back copper looking - number stamped on the chassis is the same 808593
By lowlightwarwick at 2012-06-05
Sa Motor Assemblers & Distributers Ltd
Uitenhage CP
Kombi 808593
Paint (looks like) 07
These are the plates at left side pasenger
also the silver one 11 30 52
Made in Western Germany Number 808 of the year 59 march ???
Then shipped to SA and assembled in Uitenhage between 59 and completed on clock stamp 3-61 ???
Paint code for Dove Blue 07 ??
Think the 11 30 52 some sort of number from assembly line -Uitenhage ?
Whatever the birth day is still shaking cause its here :hangloose:
Retrobug
Has thanked: 15 times
Been thanked: 32 times
Re: Warwicks Split
Post by Retrobug »
Make some good use of those shakes with a rag and polish in hand! :lol:
Flip, can't see the photo's at work :(
Will have to see the updates tonight again! :hangloose:
Re: Warwicks Split
Post by Dawie »
That chassis number is 1961 without a shadow of doubt. Notice the lower position of the top side door hinges, so it cannot be 59.
The colour code seems like it was not stamped clearly. Do you think it could have been a "Q/-" or "O1/-" or is it definitely a zero and a seven? The top of the 7 is not so clear.
Congratulations, your kombi looks in reasonably good unmolested condition.
Warwick-Lowlight
Re: Warwicks Split
Could be a Q and 7
If not looks like "Q/-"
the top if its seven is not clear
VW-rules
What model do you have?: 1961 Bus
Has thanked: 10 times
Belgium
Re: Warwicks Split
Post by VW-rules »
Looks like my bus's sybling.
Great find, enjoy.
Warwick-Lowlight
Re: Warwicks Split
@ Vw rules - give me a while and we can get these two couzzies back together
Well after following the advise and putting a rag in my shaking hand this was the result
splitbusaholic this one is just for you
Left of frame just high pressure wash - centre water wash with rag - right side water rag and then some polishing cream
Could this be the birth of a RAT
Before after wash with water
:hangloose: After wiff some cream
This is just moss for fun
:hangloose:
Warwick-Lowlight
Re: Warwicks Split
Sorry heres a better one
First still needed a bit more shaking
Klaus
Warwicks Split
Post by Klaus »
That bus is smoking hot !
Yummy yummy yummy
