Anyone seen this before
Not a part number ??
Engraved on the crown wheel - think thats what its called
Date ??
By lowlightwarwick at 2012-08-17
Another question is
1 Shimm on the gear side and no shim on the other - is this correct
Thats between the big bearing and the gear
Tha shimm is to space the Ring gear closer to the Pinnion shaft as to get the back lash right and mating patern
under the shimm is a spacer and on the other side there should also be a spacer between the diff carrier and the bearing
Those numbers is all sorts of numbers VW used to keep Ring and Pinnion sets together and by who it was manufactured
Thanks Bugger
So only one shim on the outside as a spare and the others are in the inside ?
Is there a specific torque for those nuts that hold the gear as there are another 2 that are loose
Would it be alright to put some locktight or a split washer to keep them in place and then the wire ??
