My beamish buggy rebuild & mod's
SouL
What model do you have?: Jenna Jameson
Has thanked: 20 times
Re: My beamish buggy rebuild & mod's
Post by SouL »
arnocill wrote:I'm not sure but is'nt the 009 a points dizzy? In your case fitted with an ignitor?
Since the electionic ignition burn out I had the internals changed with points...sorry I'm still learning a lot when it comes to engines (noob)...so not too sure if it has a ignitor or not :(
arnocill wrote: I used the internals from a Golf dizzy and fitted that to the stock beetle dizzy. You will get Golf distributors at any scrapyard, if it's an ignitor you're looking for try Callooker
Wonder if the Golf internals will work on the 009 as I would really like to go back to the electronic setup as that's what I orginaly wanted :roll:
PS sorry for the Hi jack
arnocill
What model do you have?: beamish buggy
Been thanked: 4 times
Post by arnocill »
You'll have to measure and compare the 009 with the Golf ditributor then, but i'm sure it will be the same diameter.
I have even used Golf internals in a bosch dizzy for a Ford and it were a perfect fit.
Check out this topic: http://www.aircooledvwsa.co.za/viewtopi ... =4&t=21472
riaanj
Been thanked: 41 times
Post by riaanj »
I Think this buggy is gonna be EPIC! :hangloose:
Just keep on BUGGIN'
T6 Ranger 2.2TDCi D/Cab
307E Anglia panel-van
Honda CBR600RR
Honda CBR600F4
arnocill
Post by arnocill »
Thanks riaanj. There was'nt lots of progress during the last two or three months, bit cold for the garage at night.
arnocill
Post by arnocill »
At last i made some progress for a change. Got the body primed, the front bumper finished, made the side bars and roll cage and stripped the rear suspension to lower the torsion bars and do the rear brakes and bearings.
snoeckie
Has thanked: 11 times
Post by snoeckie »
great work so far :hangloose:
scrappy
What model do you have?: 1974 beach buggy
Has thanked: 2 times
Post by scrappy »
Wo man that realy looks good. Interesting read,- can you pls advise, did you use the standard coil or did you upgrade? Ive done the exact conversion,and the guy from goldwagen said i can use the same coil, i installed it this morning, but cannot get it fired up. some guys are adament that i need to use a coil suitable for electronic ignition.. Advise will be much appreciated
Regards
phillip
Hloni
Has thanked: 14 times
Post by Hloni »
The "other guys" are correct. I'm sure someone else can give technical reason why they are correct.
Nice work arno. How many points are you going to secure the roll cage to onto the chassis? Will you be making a flat plate to run between from and rear upright?
3011
and the lotus 7 ???
Loopy
Been thanked: 6 times
Post by Loopy »
Tony Z wrote:and the lotus 7 ???
That's a Locost, really good looking piece of work!
arnocill
Post by arnocill »
scrappy wrote:Wo man that realy looks good. Interesting read,- can you pls advise, did you use the standard coil or did you upgrade? Ive done the exact conversion,and the guy from goldwagen said i can use the same coil, i installed it this morning, but cannot get it fired up. some guys are adament that i need to use a coil suitable for electronic ignition.. Advise will be much appreciated
Regards
phillip
I'll be using a bosch electronic coil from a golf. Electronic coils have a much higher output than a normal coil, ensuring a much stronger spark. And thats one of the reasons why you would want to upgrade to electronic ignition. Best advice i can give is go to scrapyard and buy genuine bosch coil from a golf, they very seldom give problems.
arnocill
Post by arnocill »
A previous project
http://www.aircooledvwsa.co.za/viewtopi ... 36&t=24402
arnocill
Post by arnocill »
Hloni wrote:The "other guys" are correct. I'm sure someone else can give technical reason why they are correct.
The roll cage will be secured at 4 points. The pan had been strengthened with 40x40x3 square tubing wich makes the pan quite ridged and also serve as a body lift.
A previous project
NICE!!!
arnocill
Post by arnocill »
During the last week i overhauled the maste cylinder and the rear wheel cylinders and fitted all new brakelines. I also sprayed and polished the body. Feels like i got something done for a change.
