57oval,
I will check things out for you. - Thanks Paul
I know that the 70's lids will need a change of the valance and therefore the front bonnet will have a different curve as it points to the road. The 70's engine lid as far as I know is a lot wider so I would keep away from them.
The Doors on pre 65 will fit 50's but the pattern on the inside of the door differ slightly, if it worries you. But all the bits, window winder door lever etc work.
The fenders of a pre 65 will fit the 50's. but let me cross check for you.
I can also suggest is get onto the parts suppliers like
http://www.wolfsbergwest.com and look at the fenders, they normally give year ranges eg. 50's to 64 etc.. I know that certain things are not what suppliers say especially the battery section, they say fits up to 72 but the pattern is different, same with jacking points...
I will get back to you.
