5x205 to 4x100 conversion
Stütz
Been thanked: 19 times
Post by Stütz »
Is there an adapter (as a temporary fit) for a 5x205 to 4x100 conversion on a 1974 standard bug? Alternatively should we just modify the current hub and drums to accept the 4x100 PCD? If so, who in Cape Town does this?
We will switch to discs all 'round later (Rui) but for now an adapter or mod will do. Will be fitting 205/40x17's. I assume there will be slight clearance issues too?! This is all on a standard beam.
3104
Re: 5x205 to 4x100 conversion
http://www.aircooledvwsa.co.za/viewtopi ... 72&t=28635
If you run a 35ET the rears will probably stick out slightly when using adapters. Fronts usually fit nicely
Say goodbye to your turning circle :hangloose:
Stütz
Post by Stütz »
Tony, I've read about the turning circle issue. Maybe a nice little Mendeola setup will fix that! :hangloose:
3104
or we can start a new club... the 3-point turn club
Stütz
Post by Stütz »
Tony Z wrote:or we can start a new club... the 3-point turn club
... 'at's a LOT cheaper than going Mendeola or Red9 fo sho!
3104
beetle786
Camshaft
What model do you have?: 1968 + 1303
Post by beetle786 »
Stütz wrote:Tony, I've read about the turning circle issue. Maybe a nice little Mendeola setup will fix that! :hangloose:
hi what setup s this :oops:
Click to View . Custom Graphics for your Beetle/Bus
4029
fully independant and adjustable A-arm suspension
Only R50k once you land it in SA. R35k if you walk into the shop
beetle786
Camshaft
Post by beetle786 »
Tony Z wrote:fully independant and adjustable A-arm suspension
we got to start the 3 point turn club soooon :lol:
4029
Stütz
Post by Stütz »
:lol: Classic!
3104
