Is there an adapter (as a temporary fit) for a 5x205 to 4x100 conversion on a 1974 standard bug? Alternatively should we just modify the current hub and drums to accept the 4x100 PCD? If so, who in Cape Town does this?
We will switch to discs all 'round later (Rui) but for now an adapter or mod will do. Will be fitting 205/40x17's. I assume there will be slight clearance issues too?! This is all on a standard beam.
Re: 5x205 to 4x100 conversion
http://www.aircooledvwsa.co.za/viewtopi ... 72&t=28635
If you run a 35ET the rears will probably stick out slightly when using adapters. Fronts usually fit nicely
Say goodbye to your turning circle
- Stütz
- What model do you have?: 62, 64, 71, 71
- Been thanked: 19 times
Tony, I've read about the turning circle issue. Maybe a nice little Mendeola setup will fix that!
or we can start a new club... the 3-point turn club
- Stütz
... 'at's a LOT cheaper than going Mendeola or Red9 fo sho!Tony Z wrote:or we can start a new club... the 3-point turn club
- beetle786
- Camshaft
- What model do you have?: 1968 + 1303
hi what setup s thisStütz wrote:Tony, I've read about the turning circle issue. Maybe a nice little Mendeola setup will fix that!
fully independant and adjustable A-arm suspension
Only R50k once you land it in SA. R35k if you walk into the shop
- beetle786
- Camshaft
we got to start the 3 point turn club soooonTony Z wrote:fully independant and adjustable A-arm suspension
- Stütz
