Clock repairs
Wanda
What model do you have?: 1971 kombi
Clock repairs
Post by Wanda »
Does anyone know of someone that can fix the clock in my '71 baywindow? Is it repairable? :zhelp:
Deon_Mostert
Facebook: deon_mostert@bat.com
Re: Clock repairs
Post by Deon_Mostert »
I had m one repaired. Have a look at the link
http://www.aircooledtech.com/vdo_repair/
didi
Been thanked: 38 times
Re: Clock repairs
Post by didi »
9 out of 10 times it is the fusable link that is a quick fix. I can check it out for you if you like.
_______
Wanda
Re: Clock repairs
Post by Wanda »
didi wrote:9 out of 10 times it is the fusable link that is a quick fix. I can check it out for you if you like.
Hi, where are you situated? I would appreciate it.
didi
Re: Clock repairs
Post by didi »
Faerie glen
_______
Has thanked: 36 times
Been thanked: 50 times
Re: Clock repairs
Post by flatfourfan »
Yup, dead easy fix. There is a great link on the Samba for this, I repaired mine in about 5 minutes and I suck at wiring........
Wanda
Re: Clock repairs
Post by Wanda »
please help! After the fusable link was repaired, and we tried to install the clock it would run for a few seconds it became so hot and then smoke started to come out. Obviously pulled the wire out of the clock immediately. tried a few times, but everything was just the same. On the clock it says 12 volts. Wondered if that would be too strong? Really don't know much that is why your help will be really appreciated.
Has thanked: 424 times
Been thanked: 542 times
Re: Clock repairs
here you go
These boys have always treated me good, fixed all the resto gauges I could not, at fair price.
try them...
SPEEDOMETERS, GAUGES, CLUSTERS
We do repairs to car, truck and bike gauges, as well as customising of dials. We are situated at 18 Edendale Road, Eastleigh, Edenvale. Our cellular number is 0763742993, and our landline is 0116098960. Our email contact is info "AT" speedoserve .co .za.
Hope you come right.
didi
Re: Clock repairs
Post by didi »
Wanda wrote:please help! After the fusable link was repaired, and we tried to install the clock it would run for a few seconds it became so hot and then smoke started to come out. Obviously pulled the wire out of the clock immediately. tried a few times, but everything was just the same. On the clock it says 12 volts. Wondered if that would be too strong? Really don't know much that is why your help will be really appreciated.
Sounds like your'e having fun :TIC:
Try to isolate the problem. Have you tested it outside the bus just on the battery? It could be a dead short in the wiring. Dont let the clock heat up to much, it's got plastic gears :!:
Cheers,
Didi
_______
