Clock repairs
- Wanda
- What model do you have?: 1971 kombi
Clock repairs
Does anyone know of someone that can fix the clock in my '71 baywindow? Is it repairable?
Deon_Mostert
- Facebook: deon_mostert@bat.com
- didi
- Has thanked: 9 times
- Been thanked: 38 times
Re: Clock repairs
9 out of 10 times it is the fusable link that is a quick fix. I can check it out for you if you like.
_______
- Wanda
Re: Clock repairs
Hi, where are you situated? I would appreciate it.didi wrote:9 out of 10 times it is the fusable link that is a quick fix. I can check it out for you if you like.
- didi
Re: Clock repairs
Faerie glen
_______
- Has thanked: 36 times
- Been thanked: 50 times
Re: Clock repairs
Yup, dead easy fix. There is a great link on the Samba for this, I repaired mine in about 5 minutes and I suck at wiring........
- Wanda
Re: Clock repairs
please help! After the fusable link was repaired, and we tried to install the clock it would run for a few seconds it became so hot and then smoke started to come out. Obviously pulled the wire out of the clock immediately. tried a few times, but everything was just the same. On the clock it says 12 volts. Wondered if that would be too strong? Really don't know much that is why your help will be really appreciated.
- Has thanked: 424 times
- Been thanked: 542 times
Re: Clock repairs
here you go
These boys have always treated me good, fixed all the resto gauges I could not, at fair price.
try them...
SPEEDOMETERS, GAUGES, CLUSTERS
We do repairs to car, truck and bike gauges, as well as customising of dials. We are situated at 18 Edendale Road, Eastleigh, Edenvale. Our cellular number is 0763742993, and our landline is 0116098960. Our email contact is info "AT" speedoserve .co .za.
Hope you come right.
try them...
- didi
Re: Clock repairs
Sounds like your'e having funWanda wrote:please help! After the fusable link was repaired, and we tried to install the clock it would run for a few seconds it became so hot and then smoke started to come out. Obviously pulled the wire out of the clock immediately. tried a few times, but everything was just the same. On the clock it says 12 volts. Wondered if that would be too strong? Really don't know much that is why your help will be really appreciated.
Try to isolate the problem. Have you tested it outside the bus just on the battery? It could be a dead short in the wiring. Dont let the clock heat up to much, it's got plastic gears
Cheers,
Didi
_______
