- Site Admin
- Been thanked: 54 times
Are they reinforced? I would have thought of they were only silicone they might collapse under high vacuum.
- 4agedub
- Has thanked: 4 times
- Been thanked: 13 times
The silicone tubing is strong enough not to collapse under vacuum conditions. I do not like the look though...
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
- 4agedub
- vader
- Has thanked: 9 times
Keep up the work....
- 4agedub
Got quite a lot done last night. Maybe it'll start up this weekend, then for some tuning and final assembly.
Got my turbo blanket on Monday
Air temperature sensor wired up
Crank angle sensor
Fuse box and relays for fuel pump, IC fan and 2x water sprayers
Switches, Gauges and some more fuses
Race tech display, Innovate AFR and backup oil pressure gauge
Race tech DL1 data logger
Crank angle sensor
- 4agedub
Wires now all the way into the bonnet compartment.
Fuse box and relays wired. The relays are for indicators, fuel pump, fan, water sprayer for IC and water sprayer for OC.
Boost control solenoid. Also ECU controlled
Oil pressure sender units. One for the Racetech dash and one for a backup VDO gauge.
- Bratjie
- What model do you have?: 74
- Facebook: https://www.facebook.com/juan.buter
- Has thanked: 3 times
- Been thanked: 5 times
Ahhh Louis, you're a killer builder man! Inspiration to all, keep the post's coming,
Esté robusto, ser fuerte!!!!
73 Beetle project
73 Beetle project
nice, I see you have also got a P-touch.... makes wiring so much easier dont you find?
Looks good
Looks good
- 4agedub
Yip, makes fault finding easier.
Wired up the switches and relays last night. Only dash / logger and front lights left. Maybe I can start her up tomorrow night.
- 4agedub
Got her fired up on Saturday!!! Only to find the rear main seal was pissing oil. So we "quickly" took the engine out, fixed the seal and put it back in again. Saturday evening around 7pm it fired up again and the oil leaks are gone.
I did not get to take any photos or videos. Will take some tonight.
The engine sounds pretty responsive and the turbo spools up quick. After shutting the engine down from idling the turbo spins for about 2 minutes.
nice!
Ball bearing turbos rock... oneday...
- Wentzel
- Has thanked: 6 times
Very nice build glad to hear its running.
Do you use a boost control solenoid from an Audi?
When will it be ready for action?
Oxyboxer Project
- 4agedub
Yes, it is a n75 valve from an Audi. Hopefully track day next month.
Not much happened last night on the #71 beetle.
Did another cold start setup and let the engine idle for a while and did the final setup on the Dash2. Tonight quickly set valve clearances, then I'll take a quick video.
Then spend some time on the #170 beetle and do final preps for Zwartkops this weekend.
Water tank for sprayers with pump installed and wired
Dash wiring
Two is better than one.
Final preps for this weekend on the #170 beetle. Wheel alignment done, carbs cleaned, new tyres fitted.
Dash wiring
- splitfan
- Has thanked: 46 times
- Been thanked: 26 times
Well done , hope everything works and stays together as planned and you have heaps of fun driving it !
