30 hp okrasa manifolds
didi
Been thanked: 38 times
Post by didi »
Hi Impi
I am able to supply you with 2 manifolds. Will you be able to make manifolds to fit two 28pict carbs on? I know you did something similar for someone else. What linkage did you use?
Has thanked: 235 times
I saw that engine shortly after it was built, and it was truly a work of art. I believe the linkages was custom made by IMPI, this is what the end product looked like:
IMPI
What model do you have?: sp2
Been thanked: 78 times
Post by IMPI »
Send me the carbs and manifolds and it will be done might take a while though.
A
didi
Post by didi »
Thanks Armand. I will try to make a plan to get the stuff to you. In the meantime i'll run the stock setup.
