Hi Impi
I am able to supply you with 2 manifolds. Will you be able to make manifolds to fit two 28pict carbs on? I know you did something similar for someone else. What linkage did you use?
I saw that engine shortly after it was built, and it was truly a work of art. I believe the linkages was custom made by IMPI, this is what the end product looked like:
